ron 47 Posted August 5, 2019 Share Posted August 5, 2019 Hi all Black 5 i am put a tts chip in to the black 5 tender spekes in and the wait is down all the way but the tender will not close where has the chip got to fit in the tender thank Ron Link to comment Share on other sites More sharing options...
walkingthedog Posted August 5, 2019 Share Posted August 5, 2019 Does this help? https://www.hornby.com/uk-en/downloads/view/download/item/2109 Link to comment Share on other sites More sharing options...
96RAF Posted August 5, 2019 Share Posted August 5, 2019 Was there not a similar topic where the OP had to slot the tender weight to allow the various wires to feed through and sit snug. Looks like this weight needs its two holes slotting as well. Link to comment Share on other sites More sharing options...
ron 47 Posted August 5, 2019 Author Share Posted August 5, 2019 Thank RAF96 yep i did all that got all back togethere only to find the loco has a problem so back to Hornby i think it not mine as doing it for a friend. i put a 8 pin in it still no go.Thank Ron 47 Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted August 5, 2019 Share Posted August 5, 2019 With some locos, mine being the GWR 28xx 2-8-0 tender loco, the round speaker fits fine, the weight in my case had a wedge shape to clear the speaker connexions, but there is insufficient depth above the 8 pin DCC socket in the tender to house the decoder. There wasn't a great deal of a gap, so I tried all sorts to get the tender top to fit... In the end, I decided to cut a part of the bottom of the coal space away, to allow the TTS decoder to fit in front of the rear mounted socket, on top of the weight and speaker. As the coal load is removable on the 28xx, this can be removed to do the cutting out. The coal load then covers the decoder, with plenty of clearance, and therefore ventilation. Possibly also necessary on the Black 5. Funny enough, we have an older DCC ready Black 5, decoder socket in the loco. This will be having a TTS decoder fitted. Depending on the space available, we may use a sugar cube speaker in the loco, or convert the loco to have the socket and decoder, with the speaker, in the tender... Link to comment Share on other sites More sharing options...
