slowshunter Posted September 2, 2019 Share Posted September 2, 2019 I'm having a problem with my controller. When I try to start a loco I get a flashing "EO" in the indicator window. This happens when I start the loco on the rerailer (R620) track. Any ideas ?Phil Link to comment Share on other sites More sharing options...
Chrissaf Posted September 2, 2019 Share Posted September 2, 2019 What firmware revision is the Select?.The first number that appears on the screen when you power up the Select is the revision number..I ask because EO isn't a recognised error code in the 1.1 to 1.5 Select firmware manuals. Well at least it is not documented in them. I'm wondering if you have firmware 1.6 and this is a new error code in that firmware.....possibly EO for Error Overload. Link to comment Share on other sites More sharing options...
96RAF Posted September 2, 2019 Share Posted September 2, 2019 Select v1.6Emergency Off which replaces the old Overload Protection and kills all track power as opposed to ES which stops the locos but leaves the track live.EO is automatic but can be invoked by a long press of the STOP button and ES by a short press. Recovery from either is a further press of the STOP button. Sounds like it is being triggered by a loco short. It should be described in the notes that came with the update. Edited after referring to my notes. Link to comment Share on other sites More sharing options...
slowshunter Posted September 3, 2019 Author Share Posted September 3, 2019 Thank you chaps. Great help as usual. I think I've got it sorted now.Phil Link to comment Share on other sites More sharing options...
