dlaloum Posted January 17, 2020 Share Posted January 17, 2020 Hi Folks,A bit of a grumble...We got the Western Mater set for my son - with elink/railmaster etc...All good, he has been running it.But when compared to some of the other Locos I have, fitted with 3rd party decoders (DCC Concepts and LaisDCC) - the acceleration/decceleration settings are woeful... So I took it appart thinking I will swap in an alternate decoder.... 8pin, or 6pin I thinks to myself.... but no - it is a 4pin plug in..... a complete Non-Standard....So to fit an alternate decoder I need to rewire it with a 6 or 8 pin harness (or hardwire...)I am disapointed with the decoders adjustability in terms of Acc/Decceleration in an otherwise good product - such a simple thing to get right! (and yet...) Link to comment Share on other sites More sharing options...
Chrissaf Posted January 17, 2020 Share Posted January 17, 2020 To be honest all the Hornby loco decoders are bit on the basic side in terms of adjustability. I think it is the 'It's a toy' mentality. Link to comment Share on other sites More sharing options...
96RAF Posted January 17, 2020 Share Posted January 17, 2020 All the Hornby basic decoders are based on the R8249 item and all can have their accel/decell adjusted. Set CVs 3 and 4 to a low value (0-5) for quick response or a higher value (25-50) for more sedate response. Link to comment Share on other sites More sharing options...
Sultan Posted January 17, 2020 Share Posted January 17, 2020 I would definitely hardwire a Lenz, Zimo or DCC Concepts decoder instead of the Hornby 4 pin. Link to comment Share on other sites More sharing options...
dlaloum Posted January 18, 2020 Author Share Posted January 18, 2020 Hi raf Yes I tried that, but the most gradual accel/deccel I could get was far more expeditious than desired. ( stops within an engine length or 2) hence the disappointment. But if you tell me that a better response should be possible, I will recheck my cv's and try reprogramming.... Link to comment Share on other sites More sharing options...
Howbi Posted January 18, 2020 Share Posted January 18, 2020 Don't forget the weight of the 0-6-0T is much lighter than say a 4-6-2 Tender loco, some of which have better motors with flywheels so the performance re: accel/decel will be markedly different.........try adding some weight to the 0-6-0 and resetting CVs 3 & 4........BEMF is affected by the load on the loco also........HB Link to comment Share on other sites More sharing options...
96RAF Posted January 18, 2020 Share Posted January 18, 2020 I am not at all sure if you an instant stop/start or a gentle one. Instant stops then set a low value or if you want it to take its time accelerating or decellerating bung in a high value e.g. 255 will see you setting it of, having your dinner and it may have moved a bit. 5 is the default for these CVs. Link to comment Share on other sites More sharing options...
jane1707819582 Posted January 18, 2020 Share Posted January 18, 2020 Hi raf Yes I tried that, but the most gradual accel/deccel I could get was far more expeditious than desired. ( stops within an engine length or 2) hence the disappointment. But if you tell me that a better response should be possible, I will recheck my cv's and try reprogramming....The rate of acceleration is also dependent on your selected speed steps Link to comment Share on other sites More sharing options...
