Trainmodeller35 Posted February 17, 2020 Share Posted February 17, 2020 I'm trying to design my first layout, but I'm awful at drawing so it's really hard to put my design on paper. Does anyone know of a good computer programme to use to create my design? Should I start building and not worry about the design? Link to comment Share on other sites More sharing options...
Chrissaf Posted February 17, 2020 Share Posted February 17, 2020 Choice of two Windows PC applications. Both offer free evaluation versions but these have restricted number of track elements..SCARM - Simple Computer Aided Railway ModellingAnyrail.TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
RDS Posted February 17, 2020 Share Posted February 17, 2020 I bought AnyRail, which is also available as a free trial with limited features.The support was excellent as well when I had a question and an item I requested, was added to it in quick time. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 17, 2020 Share Posted February 17, 2020 I had a similar experience with SCARM.....the author made an amendment to the application at short notice to fix my reported issue. Link to comment Share on other sites More sharing options...
96RAF Posted February 17, 2020 Share Posted February 17, 2020 Scratching out a design on paper has the advantage of speed and it is easily changed, but a computer program will highlight where your dream layout doesn’t actually work as it won’t fit in the space you have. I have sketched out a basic requirement for a layout then gone ahead with in my case Scarm to draw it in accurate detail. Thrn it has to be changed a million times to get it to work as a decent running layout. Others say just put track on boards and see how it goes. It all depends if you have a ‘plan’ about what sort of layout you want - is it a replica of somewhere, or just track doing interesting things. Link to comment Share on other sites More sharing options...
walkingthedog Posted February 17, 2020 Share Posted February 17, 2020 If you have an idea in your head you can easily make a rough sketch, then lay some track. You can then adaptvas you go. Link to comment Share on other sites More sharing options...
