Jimbo1707820979 Posted March 19, 2020 Share Posted March 19, 2020 I have tried several methods to restore proper running to this Hunt Class loco which was bought new, DCC fitted, in 2016 and carefully run in and performed well. My recent efforts to run it again have all failed. Using CV29 I switched it to DC allowed but it will not run on analogue either. If the decoder has failed, would it not run on DC until the decoder is removed and a blank fitted ? Or could there be a more serious fault ?I would be grateful for some advice. Link to comment Share on other sites More sharing options...
Howbi Posted March 19, 2020 Share Posted March 19, 2020 Have you tried running with the blanking plate in?......HB Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 19, 2020 Share Posted March 19, 2020 Runnning on DC with the decoder fitted, power must still go via the decoder to the motor. So if the decoder has failed, it is unlikely to run. Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted March 20, 2020 Author Share Posted March 20, 2020 Thankyou, Gents. I wish to remove the decoder now but could you please tell me if it is in the loco or the tender ? The Sevice Sheet gives no info. I have some spare blanking plates so that is no problem. Hopefully, the removal of body/tender shell will not give too much trouble. Link to comment Share on other sites More sharing options...
Howbi Posted March 20, 2020 Share Posted March 20, 2020 According to Sam's Trains review video the manual shows the decoder socket in the tender and also a shot of the loco & tender clearly shows the four wires connecting them so if your model has the same four wires then the decoder will be in the tender........HB Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted March 20, 2020 Author Share Posted March 20, 2020 Thanks, HB. I will also have a look at the Sam's Trains review. Yes, my loco has the 4 wires in a braided plastic connection over the draw-bar. Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted March 20, 2020 Share Posted March 20, 2020 The Hunt class does indeed have the decoder socket in the tender. The tender body is clipped on, the same as the tender drive locos. In theory, if you squeeze the front and back, the sides should now out slightly, freeing off the clips. It may also be possible to carefully insert a screwdriver, or similar, up inside the rear part of one side of the chassis, and push the bottom of one side outwards to free the clips... They can be stubborn things... We have the Cotwold Railroad DCC ready chassis under the old tender drive Yorkshire... Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted March 21, 2020 Author Share Posted March 21, 2020 Success ! I removed the tender shell by very, very gently levering it up with the blade of a craft knife. On my "The Burton" it is a downwards-slide fit with 2 small locating blips at the front of the chassis.. After removing the decoder and pressing in a blanking plate the loco ran perfectly on DC. This is the second decoder which has failed during storage for no apparent reason. The other was in my Heljan "Lion" so no connection.Thanks to all for your comments. Link to comment Share on other sites More sharing options...
Howbi Posted March 21, 2020 Share Posted March 21, 2020 Thankyou for the feedback, Jimbo............HB Link to comment Share on other sites More sharing options...
96RAF Posted March 21, 2020 Share Posted March 21, 2020 Out of interest which make and model were these expired decoders. Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted March 21, 2020 Author Share Posted March 21, 2020 "The Burton" one was factory fitted, so presumably a Hornby regular. As to the "Lion" I believe I was the second owner and it also had a factory fitted decoder. Sorry I can't be more specific. Would you like a photo of the Hornby ? Link to comment Share on other sites More sharing options...
