St1ngr4y Posted May 21, 2020 Share Posted May 21, 2020 Yes, Inknow the message you mean. Strangely it says the Elite is active but the eLink is "Inactive". However, it all works so I am not going to rock the boat like I did with com port changes. I have the same setup as you, and yes, Elite is Active and eLink is Inactive, yet both are working fine. Ray Link to comment Share on other sites More sharing options...
Exetersteam Posted May 21, 2020 Author Share Posted May 21, 2020 Yes, Inknow the message you mean. Strangely it says the Elite is active but the eLink is "Inactive". However, it all works so I am not going to rock the boat like I did with com port changes. I have the same setup as you, and yes, Elite is Active and eLink is Inactive, yet both are working fine. RayThanks Ray. I find that reassuring. I will let you know how it works out with two Elites. John Link to comment Share on other sites More sharing options...
Exetersteam Posted May 25, 2020 Author Share Posted May 25, 2020 Well, sadly I can't yet tell you how it works with two Elites. The new one arrived this afternoon and I didn't even take it out of it's plastic bag let alone plug it in to anything. I picked it up only to discover that it did a passable impression of a baby's rattle. Definately some loose components rattling around in there. So that one is going back as well. You couldn't make it up!The existing set up is still working although I still get the occassional USB message and Railmaster tries to up date the eLink to version 1.07 every thime even though I have manually updated it. Link to comment Share on other sites More sharing options...
