Paul Cotterill Posted July 29, 2020 Share Posted July 29, 2020 Hello everyone,Ive just recieved my collector club loco 2020 but need to convert it to DCC (I believe it is DCC ready.) Can anyonee tell me the part number of a decoder that will work please?Many thanksPaul Cotterill Link to comment Share on other sites More sharing options...
5Dublo2 Posted July 29, 2020 Share Posted July 29, 2020 I have mine too, not tried to convert it to DCC yet, however I believe it is not DCC ready and you have to use a soldering iron and follow these notes (which are for a different body on the same chassis):https://www.hornby.com/uk-en/hornby-dcc/decoder-installation-guides/standard-0-4-0-decoder-installation-guideNote: being new to this I hope I have the correct info Colin Weaver Link to comment Share on other sites More sharing options...
RDS Posted July 29, 2020 Share Posted July 29, 2020 Colin is right, the Collector Club Loco is NOT DCC ready, although as he says it can be converted with a bit of soldering.Any standard Decoder such as the Hornby R8249 is suitable. Link to comment Share on other sites More sharing options...
Howbi Posted July 29, 2020 Share Posted July 29, 2020 It is easier to fit the Hornby R7274 4-pin decoder with just four wires..........Grey & Orange to the motor, Red & Black to the pickups........also remove the small yellow suppression capacitor, it is not needed on DCC.......here's one I made earlier...........HB/media/tinymce_upload/7674bb798a710dbcf8579af9cbdc6e21.jpg Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 29, 2020 Share Posted July 29, 2020 Check when you remove the body to do your installation whether the motor is mounted with the terminals pointing down, or pointing up. The guide assumes they are pointing down so has all the steps to remove the motor to get at them, then to replace it. If the terminals are pointing up, you don't need to remove the motor. It's a simple conversion of unsolder everything from the motor terminals, discard any and all components then solder decoder red and black to the pickup wires each side, then orange and grey to the motor terminals. Doesn't matter which side red and black go but the loco goes backwards if you get orange and grey reversed. Test with the body off and swap them if you get them wrong. Link to comment Share on other sites More sharing options...
5Dublo2 Posted August 8, 2020 Share Posted August 8, 2020 Thanks Howbiman ad Fishmanoz - I just converted mine with the 4 pin decoder and my motor terminals were pointing upwards too. I did have to reverse the direction of travel to match my other locos (which I guess is to do with which side of the motor you attach the grey and oraange wires to) Bit of a tight fit to get the body back on afterwards ;) Link to comment Share on other sites More sharing options...
