WoodyzR Posted August 10, 2020 Share Posted August 10, 2020 Hi AllI have a 584mm straight with the C8545 powerbase attatched which I no longer need the powerbase for as I have ARC Pro.Is it possible to remove the powerbase from the track without doing any damage, so I can just use the track as a standard straight? If so can someone give me a brief guide.Thanks in advace. Link to comment Share on other sites More sharing options...
gorp Posted August 10, 2020 Share Posted August 10, 2020 Well should be easy enough to pry off base and cut track wires.Just disconnecting the wire under the track should be enough and you could then reverse it.But should you. Real answer depends on which version of arc pro you own.You should go over to slotracer.online to check missing arc manual where you can find out about different versions.The original had problems with analog and digital and best solution was the riko mod at slot forum which made it a great digital only powerbase and then you would swap in an analog base if required.So read the manual and check your arc pro version first. However 584 is equal to full straight plus 3 shorts , so you probably need it to balance out your track, so understand your reasoning to salvage it. Link to comment Share on other sites More sharing options...
WoodyzR Posted August 10, 2020 Author Share Posted August 10, 2020 Thanks for the reply. I bought the ARC Pro as a stand-alone unit in Dec 19, as opposed to it coming with a set. Will go and have a browse as suggested. I havent had any issues with my ARC Pro, I only run digital though. Thanks again Link to comment Share on other sites More sharing options...
Andy P. Posted August 10, 2020 Share Posted August 10, 2020 I have removed the powerbase bits to make it into a straight with no problem.Just be careful of sharp edges etc Link to comment Share on other sites More sharing options...
WoodyzR Posted August 11, 2020 Author Share Posted August 11, 2020 Andy PCan you tell me how to remove it? Do you have to butcher it? Wire snipper jobs etc or will it just unscrew and unclip? Link to comment Share on other sites More sharing options...
Andy P. Posted August 11, 2020 Share Posted August 11, 2020 I see this is the newer powerbase. I personally have not "de powered" this one but I reckon it is a matter of unscrewing the base and detaching the power from the rails.I am guessing the rails are stamped so you will have to snip or wiggle them.That should be it.There is really nothing you could do wrong except render the piece incapable of being used as a spare piece of track which would require you dropping it on the highway at 60 MPH and letting an 18 wheeler run it over . :-) Link to comment Share on other sites More sharing options...
WoodyzR Posted August 11, 2020 Author Share Posted August 11, 2020 Haha fair enough - so just unscrew the base and a bit of force and wiggling should detach the power rails! Will give it a go! Link to comment Share on other sites More sharing options...
WoodyzR Posted August 13, 2020 Author Share Posted August 13, 2020 Thanks Andy - managed food get it all detatched with ease and a bit of careful force! Link to comment Share on other sites More sharing options...
