john_ruddy Posted April 13, 2021 Share Posted April 13, 2021 I've just bought and fitted a TTS decoder into my Hornby J36, leaving aside the issues of trying to get it to actually fit inside the loco it was designed for, I have been plagued with poor running. The loco was tested on my layout on DC, and run in, and the performance, even at slow speed was really good. However, it now has a stutter. It seems to stall, which obviously causes the sound to stop and then restart. On occasion, the loco will restart by itself, but usually it may need to the tiniest of nudges. The track is well cleaned, other locos do not have the same problem. Here is a clip of the problem in action: Now I have, on advice from elsewhere, changed some of the CVs, which seems to have improved things somewhat. But its not cured it. CV150=1CV153=255CV154=1Any suggestions? I am using a Bachmann Dynamis if that has any bearing. Link to comment Share on other sites More sharing options...
96RAF Posted April 13, 2021 Share Posted April 13, 2021 It may be a case of sending it back to Hornby for investigation John. Call them for a returns number. Link to comment Share on other sites More sharing options...
Howbi Posted April 13, 2021 Share Posted April 13, 2021 @John.........I have several TTS steam decoders and I have only ever changed CV150 to 1 and always achieved smooth running. I would suggest you return CV153 to default 215 and CV154 to default 115, do a test run and report back your findings........HB Link to comment Share on other sites More sharing options...
john_ruddy Posted April 13, 2021 Author Share Posted April 13, 2021 @John.........I have several TTS steam decoders and I have only ever changed CV150 to 1 and always achieved smooth running. I would suggest you return CV153 to default 215 and CV154 to default 115, do a test run and report back your findings........HB Is this common with the Steam ones? I've fitted a couple of Class 66 ones and they've really worked fine out of the box. Link to comment Share on other sites More sharing options...
Howbi Posted April 13, 2021 Share Posted April 13, 2021 I have found that changing CV150 to 1 has always resulted in smoother running in both Steam and Diesel versions of the TTS decoder.......HB Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 14, 2021 Share Posted April 14, 2021 If you want more info about changing motor algorithms via CV150, take a look at https://uk.hornby.com/community/forum/jerky-ringfield-motor-?ccm_paging_p=2&ccm_order_by=&ccm_order_by_direction= Link to comment Share on other sites More sharing options...
john_ruddy Posted April 15, 2021 Author Share Posted April 15, 2021 Well, I've been fiddling about with the CVs, and while its not perfect, I think its better. Link to comment Share on other sites More sharing options...
