Terence-1215008 Posted August 20, 2021 Share Posted August 20, 2021 I have a flying scotsman train set and have fitted a DCC decoder. What TTS decoder do I need for this train and is it easy to fit? Link to comment Share on other sites More sharing options...
96RAF Posted August 20, 2021 Share Posted August 20, 2021 A1 or A3 or even Tornado.Depending upon which FS train set it is will depend if it has a socket for the decoder or not and if so whether the socket is in the loco or tender, as there have been lots of FS variants over the years.As you have already installed a decoder you will be able to say where this went and if there was a preexisting socket.Tell us the R number of the set and we can further advise. Link to comment Share on other sites More sharing options...
RDS Posted August 20, 2021 Share Posted August 20, 2021 @TerenceModerator Note:Could you please select the 'View my Community’ in your Dashboard on the Forum and choose a nickname in the ‘My profile' tab, rather than your First name that has been automatically allocated by the system. Hopefully a Forum change is coming soon to prevent this automatic allocation but a manual change is required at the moment and there will be more than one member with your name. Link to comment Share on other sites More sharing options...
Howbi Posted August 20, 2021 Share Posted August 20, 2021 Simply remove the existing decoder that you fitted previously and replace with the TTS decoder. If this is in the tender there may already be a dedicated space for the round speaker that comes attached to the TTS. If not then you may have to discard the round speaker and replace with a "sugar cube" type rectangular speaker of a size that fits the space available. But as 96 RAF says it would help if we knew the Rxxx number from the loco or Set.........HB Link to comment Share on other sites More sharing options...
