AceinOz Posted October 10, 2021 Share Posted October 10, 2021 What do people use to connect dropper wires to the bus wire? I know one method is to solder. What about using suitcase (Or scotch lock?) connectors? If so, what size - AWG14-16? Link to comment Share on other sites More sharing options...
morairamike Posted October 10, 2021 Share Posted October 10, 2021 I soldered mine after wrapping the dropper around the buss wire. Reason for this is it's unlikely to come apart or go high resistance. As it's under the layout access isn't always easy later. Link to comment Share on other sites More sharing options...
96RAF Posted October 10, 2021 Share Posted October 10, 2021 I used 5 x junction boards. The bus feeds in one side, droppers are attached to the + and - bus rails and the bus continues out the other side to the next one. There is a handy three way led power indicator to show DCC, DC>> or DC<<.These are mounted topside for convenience of connection and the boards hidden by a suitable building, etc. The dropper wires still need to be soldered to the rails.The last one has a bus terminator fitted to protect against spikes that may occur if a loco derails or in event of some accidental short circuit. Link to comment Share on other sites More sharing options...
Flashbang Posted October 10, 2021 Share Posted October 10, 2021 Twisted & soldered. Screw terminal blocks. Wago 221 or similar style connectors. Ready made connector blocks. Suit Case/Scotchlok connectors (must be of the correct colour size though). Earthing bus blocks. Barrier strips.All are suitable, it is really what is right for the end user. grinningOf all those I've listed, the Wago 221 style is probably the easiest to use and rewire into. In case you don't know what Wago style connectors are, they come in 2, 3 and 5 way internally connected blocks. Wago example...https://www.wago.com/gb/electrical-interconnections/discover-installation-terminal-blocks-and-connectors/221 Link to comment Share on other sites More sharing options...
Brew Man Posted October 12, 2021 Share Posted October 12, 2021 Just got some WAGO 221 5 way connectors that Flashbang mentions and they look really great and straight forward to use. The 5 way will allow one bus wire in and one out then 3 dropper connections, or you might be able to squeeze two wires into each slot and get more droppers connected. Of course you'll need two connectors in total for each junction location - one for each phase of the bus. If you're going to have to crawl under the base board they will be much easier to use than terminal blocks. Link to comment Share on other sites More sharing options...
