slowshunter Posted November 11, 2021 Share Posted November 11, 2021 Hi, I've got a problem with my Hornby Select controller. Yesterday it was working perfectly allowing me to input code numbers for my locos. Today it isn't even powering my DCC locos and it is not allowing me to input code numbers. When I tryto do this the light on the controller flashes 8 times! It won't me to re-input numbers to the locos I have already installed. HELP! Link to comment Share on other sites More sharing options...
96RAF Posted November 11, 2021 Share Posted November 11, 2021 Do you know what firmware revision state your Select is - first number seen at power up followed by 30 then 03.If it is 16 or 20 you may have inadvertently entered programming mode.Switch it off and on again noting the firmware number, then write down each key stroke you make and what you see. Link to comment Share on other sites More sharing options...
slowshunter Posted November 11, 2021 Author Share Posted November 11, 2021 Thank you for that. I'll do this in the morning.Cheers,Phil Link to comment Share on other sites More sharing options...
Chrissaf Posted November 11, 2021 Share Posted November 11, 2021 The 8 flashes indicates that the Select is probably in CV configuration (programming) mode as Rob above has surmised.If this is indeed the case, then note that any and all DCC devices (locos etc) that were / are connected to the Select track output at the time you saw the 8 flashes may have had their existing configuration accidentally changed. You might (in the worst case scenario) have to reset and re-configure all your decoders. Reset is writing 8 to CV8. When the Select is in CV configuration mode, only one single DCC decoder device can be connected to the track at a time.The Select sends 'programming' commands as a broadcast and ANY & ALL devices connected to the track output will respond. Thus the reason previously working locos have now stopped working could be because you have changed their configurations in error and they are no longer responding to their previously configured DCC Addresses. Link to comment Share on other sites More sharing options...
slowshunter Posted November 12, 2021 Author Share Posted November 12, 2021 OK Thank you for that although I'm not sure what it means as I have absolutely no knowledge of electronics. So I'll do what 96RAF has suggested later today. I'll come back for more advice if that fails. So fingers crossed....Thank you to everyone in this Hornby Forum. The knowledge you have is incredible.Cheers,Phil Link to comment Share on other sites More sharing options...
slowshunter Posted November 13, 2021 Author Share Posted November 13, 2021 Hello again, When I turned my Select On the only numbers that came up immediately were 30 followed by 03 followed by 11. I think 11 was the last code I tried to input onto the controller. Any ideas.Cheers,Phil Link to comment Share on other sites More sharing options...
Chrissaf Posted November 13, 2021 Share Posted November 13, 2021 It seems to me that your attention to looking at the Select screen was slightly delayed as you powered up the Select. You have to be quick as the firmware number does not stay on screen very long. It appears before the number 30.If the firmware version number genuinely didn't appear then I suggest performing a Select factory reset as documented in the Select manual. But note that if your Select is version 16 or 20 then you need to follow the 'Reset' method in the Version 16 manual addendum downloadable from this Hornby website support section. Link to comment Share on other sites More sharing options...
96RAF Posted November 13, 2021 Share Posted November 13, 2021 At a successful power up the last number on screen should be 03 which is the default address and that tell us the Select has booted correctly and is ready for use. You then manually input the address you wish to use and press Select. The loco should react to that address.You should as Chris suggests perform a unit reset following the steps in the correct version of the manual. This will put the Select into a known state.If your Select is as suspected at rev 1.1 (first number seen 11) then you would be wise to get it updated by Hornby as rev 1.1 has a bug that can damage accessory decoders. If not at this rev then tell us what the first number seen is. Link to comment Share on other sites More sharing options...
slowshunter Posted November 13, 2021 Author Share Posted November 13, 2021 You should as Chris suggests perform a unit reset following the steps in the correct version of the manual. This will put the Select into a known state. Thanks yet again, I'll do this tomorrow, Many thanks.Cheers,Phil Link to comment Share on other sites More sharing options...
slowshunter Posted November 13, 2021 Author Share Posted November 13, 2021 OK Thank you Chris.Cheers,Phil Link to comment Share on other sites More sharing options...
slowshunter Posted November 16, 2021 Author Share Posted November 16, 2021 Hi, Good morning 96RAF, you and Chris have been brilliant and the reset has worked. Thank you both. I have to say sorry that I 've taken some time to get back to you. You see, I've suffered a stroke and my mobility is pretty awful. Anyway, it's done now but another problem has arrived and that's the sound function. To start the sound I press Function0. I try to press both buttons at the same time. Usually the screen either shows "On" or "Off" but now it doesn't. So I cannot fire up the sound. Any ideas? Link to comment Share on other sites More sharing options...
96RAF Posted November 16, 2021 Share Posted November 16, 2021 Sound on/off is F1. F0 is lights. F0 is slightly different in that if you just press Function it assumes zero. All other functions as Chris says below. Link to comment Share on other sites More sharing options...
Chrissaf Posted November 16, 2021 Share Posted November 16, 2021 You don't press F and 1 together. You press them sequentially. But you have to press the numbers first before you press the Function button.Note that the DCC Address of the loco has to be selected first and the loco address (a number between 1 and 59) has to be displayed on screen before implementing the Function option.So for example, switching on Function 1 for Loco Address 15 would be these key presses.Press 1Press 5Press Select15 displays on screenPress 1Press FunctionFunction 1 switches onAssuming a new loco address has not been selected.Press 1Press FunctionFunction 1 switches off.Note that with 'play once' sounds like a horn or whistle for example, you have to send the Function number twice. Once to switch the function 'on' and again to switch it 'off'. Hence the fuller description above for the F1 example.For double digit Functions (12 for example), after selecting the loco DCC address you would press 1 followed by 2 followed by Function. Link to comment Share on other sites More sharing options...
