Help: Ginetta Car making a funny noise.
My first inclination would be to remove the body screws and make sure the rear axle is properly seated. Also look at the motor and how it is snapped in as well. From what I hear those would be my first two places to check.
Finally, while you have the body off the car look at the gears and make sure they have just a small amount of lubrication on them. You can get some silicon grease or model lube to take care of this. You won't need a big container of lube as you won't have to lube the cars much.
