eric-1242355 Posted February 10, 2022 Share Posted February 10, 2022 Hi I have just bought a dcc digital mallard. I’m a newby to these. Could anyone enlighten me on how to get it going? Do I need a dcc controller to make it work? Thanks Link to comment Share on other sites More sharing options...
RDS Posted February 10, 2022 Share Posted February 10, 2022 @eric, while you wait for an answer please follow the information in this thread.Important Information for New Members Registering for the Forum (Updated 31st Jan 2022) :: Hornby Hobbies Link to comment Share on other sites More sharing options...
Rog RJ Posted February 10, 2022 Share Posted February 10, 2022 First of all, is it DCC ready or DCC fitted?DCC ready models have a socket fitted for you to plug a decoder into. Until a decoder is fitted it will work as an ordinary analogue loco.DCC fitted models are designed to be run by a DCC controller but you may be able to run it on a dc (analogue) controller, depending on certain conditions and restrictions, but without being able to operate any of the extra bits such as lighting (if fitted) Link to comment Share on other sites More sharing options...
Chrissaf Posted February 10, 2022 Share Posted February 10, 2022 If the Mallard DCC is a TTS Sound version, then it will not run "out of the box" on Analogue DC and even if it did, it would not be able to play any sounds. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 10, 2022 Share Posted February 10, 2022 Adding to Chris if DCC TTS, while it won’t run out of the box on DC, an adjustment can be made (alter CV29) using a DCC controller so it will. Maybe your local model shop could help. Link to comment Share on other sites More sharing options...
Jupiter 1707822591 Posted February 11, 2022 Share Posted February 11, 2022 Hi Eric.To use the mallard to full DCC capabilities then yes .If your loco is DCC fitted then you can remove the decoder and fit a blanking plug This will revert your loco back to a DC loco.A DCC ready loco should work straight out of the box . Link to comment Share on other sites More sharing options...
Will Hay Posted February 11, 2022 Share Posted February 11, 2022 It would help if you could outline what equipment you currently have, in particular that you have a DCC controller such as the Hornby Select. Link to comment Share on other sites More sharing options...
