Nick73 Posted March 24, 2022 Share Posted March 24, 2022 Hi finally got my BR 0-6-0 class 08 shunter R3898tts after a very long wait looked in the loco list to add it and its not in the listing how to i go about adding it to run with all the sounds etc on railmaster Nick Link to comment Share on other sites More sharing options...
RDS Posted March 24, 2022 Share Posted March 24, 2022 Do you have the latest version of RailMaster loaded? Link to comment Share on other sites More sharing options...
Nick73 Posted March 24, 2022 Author Share Posted March 24, 2022 not sure to be honest how do i check to see if i got latest update i just thought coz it is literally a new model that's just come out it won't be on the list Link to comment Share on other sites More sharing options...
96RAF Posted March 24, 2022 Share Posted March 24, 2022 Search on any Class 08 picking one with TTS from the list returned, noting that RM only allows you to use RxxxxTT not TTS due to length of field in the database.All 08TTS locos have the same sound sets, so any will do to list up the functions and you can hunt for the exact model picture and apply that to the loco setup screen. Link to comment Share on other sites More sharing options...
Nick73 Posted March 24, 2022 Author Share Posted March 24, 2022 ok many thanks il give that ago also only got one train running flying scotsman tts under dcc id 003 detection id 003 do i need to change these id,s before i add the new loco as it will have a id 003 from new Link to comment Share on other sites More sharing options...
RDS Posted March 24, 2022 Share Posted March 24, 2022 Each Loco must have a separate id, otherwise if they all have the same one, they will all move when it is called up.It is usual to change the 03 Default address to something more meaningful. For example as I only have one of each class of Diesel, they are numbered 08, 37, 47 etc. For Steam Loco's I usually pick the first 2 digits of the running number.Just a personal choice! Link to comment Share on other sites More sharing options...
Nick73 Posted March 24, 2022 Author Share Posted March 24, 2022 ive manged to add the logo with a class 08 tts and changed the picture logo ddc 05 and detection id 003 thats the only one showing and loco doesnt work Link to comment Share on other sites More sharing options...
96RAF Posted March 25, 2022 Share Posted March 25, 2022 You do not need anything in the detection ID as loco detection system has not been released for sale yet. Nor do you need anything in the voice control detection block unless you intend to run by voice control which I would not recommend at this stage of your learning curve.As well as picking a new Loco ID in RM you also have to write this address to the loco decoder by putting it on a programming track connected to the controller Prog terminals. Link to comment Share on other sites More sharing options...
