Desirable features for future Railmaster Software updates
@St1ngr4y
Ray
Further to your comment above (and my answer) re the 'Stop the Program' icon, I have noticed that when RailMaster is first loaded and until a program has been run completely, that hovering over the icon correctly displays 'Run the Program'.
It
is only after a program has been run that it then always incorrectly shows 'Stop the Program'.
It then remains incorrect until RailMaster is closed down and re-started.
  • Replies 516
  • Created
  • Last Reply
Top Posters In This Topic
In another thread I have described a method of running a chosen program at RM Startup. This means there are three different ways of configuring RM:-
1. The System Settings window
2. The Railmaster.ini file
3. By a command line parameter.
Could
not categories 2 and 3 be merged with category 1 so that all of the settings are accessed in a similar way?
Ray
3. By a
Could not categories 2 and 3 be merged with category 1 so that all of the settings are accessed in a similar way?
Ray
My guess is that the settings in 1 are stored in 2 (or should be!) so the latter gives a quicker
way of developing 'programs'. Option 3 gives flexibility of when/how to run 'programs'. Therefore I think all 3 should be retained. Sorry to disagree!
MetmanUK said:
My guess is that the settings in 1 are stored in 2 (or should be!) so the latter gives a quicker way of developing 'programs'. Option 3 gives flexibility of when/how to run 'programs'. Therefore I think all 3 should be retained.
Sorry to disagree!
I think your guess is wrong - none of the items in System Settings are in the .ini file nor vice versa. There is an entry in System Settings to specify the name of the layout to load up at start, so why can't the program to
be run at start be in there too.
Ray
@St1ngr4y
I agree with you.
To me the settings window is the obvious place to have this, using a drop down box, similar as you say to the start up layout. This could also be left blank for those who do not want to use the feature.
We have already
asked higher up this thread for the start-up zoom level to be included on the settings window and I am hopeful that this is already being addressed by the Hornby RailMaster team in a future update.
@RDS
Ok, I'll start with this one...
It's good that when designing your layout, you can assign default positions for each point and signal, and that you have the choice of having RM fire each point or set each signal when the layout is loaded. However,
I have about 45 points and 24 signals on my layout, and I found that allowing RM to set them all to their start values was taking a long time. I was wondering if it would be possible to leave blank the start values of those items you want to omit from the
startup routine. For example, you may find it unnecessary to set all of the points in a fiddle yard, but desirable to set all of the points on the main line. In this way, the setting of your chosen items at startup would take less time to complete. Having
set startup values on all of my points when I designed the layout, I tried to blank some of them, but the layout designer (currently) won't let you do this.
Ray
The points icons in v1.54 now have arrows, pointing Left & Right and this is to aid those people, (myself included) that suffer from Colour Blindness.
However, when selecting the Layout Designer screen, one of the options down the Left hand Side is
an Icon marked 'Add Point Control Button and other Functions'. This icon shows a picture of the points icons. Even with a Red / Green colour blindness problem, I can easily see the difference and identify the colours. When the Points icons are selected and
positioned on the screen, they then become completely different colours, which to me are nothing at all like the colours used on the Left Hand Side and certainly do not look like Red & Green any more.
Could the colours on the Layout be the same as the colours
on the icon please.
Also, the arrows seem a reasonable idea when the point is shown in a vertical piece of track but when the point is horizontal, the arrows seem to me to point in the wrong direction, by 90 degrees. Or I have I misunderstood the purpose
of them?
The red and green point control buttons cannot be made optional in favour of just pressing the point itself.
Only allowing toggling of a point is not a good idea as users may wish to switch a point in a particular direction if it is a( sticky or
b) if they are not sure they pressed it in the first place.
The red/green, left/right functions also follow in the programming system and through the hand-held devices.
@HornbyRailMasterSupport
Thank you for your comments.
Do you have a view on my comment earlier today regarding the very dark colours chosen for the point buttons compared to the nice bright Red / Green displayed on the Design screen icons.
Why not?
If a user looks at the blue indicator, they will know which
way the point is switched.
Incidentally, if & when diagonal points are introduced, where will the red/green buttons 'snap' to?
Only allowing toggling of a point is not a good idea as users may wish to switch a point in a particular direction if it is a( sticky or b) if they are not sure they pressed it in the first place.
The
This is why the word 'optional' was used. Those people who prefer the red/green buttons could OPT to use them for the reasons (a) and
(b) you give. Then those who would prefer to click the point itself to toggle it could OPT to do without the buttons.
Could you clarify the final sentence please - I don't understand it.
Ray
Please always use a unique version number for a change to the RailMaster software.
Even the smallest of changes MUST have a new number.
For example, there are (at least?) 2 different versions of the software, both carrying the version number
of 1.54. In this instance, the user may not know which version they have loaded and the RailMaster software is unable to prompt the user to update.
When a Help Request is issued through Railmaster itself, can a unique reference number be allocated to it please? This way, if no resolution has been forthcoming after a reasonable amount of time, the user can request an update via email quoting this reference
number.
Ray
St1ngr4y said:
Why not?
If a user looks at the blue indicator, they will know which way the point is switched.
They're
saying the red and green are part of the programming system so can't be changed without affecting the whole programme.
OK you asked for it...
What is being suggested is to use the point icona themselves in the Layout Designer to configure the points i.e set their addresses, decoder types, default settings, routes etc., and to make the red/green buttons optional extras
for actually switching the points when they appear on the main screen.
The program code to do the configuration is already there - it is called when you right click a red/green button. All they need to do is call this code when you right-click the point
icon. The .pln file which is used to hold your designed layout may need changing if there are two records, one for the buttons and one for the point, to store the configuration information in the other one. All of the points except the Y points, are already
capable of being switched by clicking on the point itself rather than the red/green buttons. This feature simply need to be extended to include the Y points too.
buttons optional extras for actually switching the points when they appear on the main screen.
right-click the point icon. The .pln file which is used to hold your designed layout may need changing if there are two records, one for the buttons and one for the point, to store the configuration information in the other one. All of the points except the
Y points, are already capable of being switched by clicking on the point itself rather than the red/green buttons. This feature simply need to be extended to include the Y points too.
I agree with S'R4y it is all fairly simple. Here is an example
extracted from something I worked on a while ago:
Essentially you define a point (T1 et seq), its type (L or R), angle (0, +/-45 or 90) and position on the plan (grid x,y), then its addressing states (0 or
1). If state-0 then send dcc signal to that acc decoder address, value or if state-1 then send it to the other port. After that it is as easy to link what the the lights/signals do to match those states.
Lets try it in simplified plain text
Turnouts T1
pointright45 rotation is 0 gridx is 3 gridy is 5
state state-id is 1
accessory system-id is dcc address is 1 value is 1
end of that state
state state-id is 0
address is 1 value is 2
end of that state
end of that pointright45
