Dosser16 Posted March 17, 2014 Share Posted March 17, 2014 Hi I am new to DCC. I have bought the DCC freight train set which I am making up using flexitrack. Can I also connect a piece of N gauge track and wire it to the OO track so as to run a DCC N gauge engine. Many thanks. Link to comment Share on other sites More sharing options...
Rog RJ Posted March 17, 2014 Share Posted March 17, 2014 You could if you wanted to but it may be better to have the DCC controller connected to one or the other, rather than having them both connected at the same time. Link to comment Share on other sites More sharing options...
96RAF Posted March 17, 2014 Share Posted March 17, 2014 DCC has not a clue about how wide the track is so in theory at least you could run all gauges at once from the one controller, to resemble a model railway within a model railway within a model railway...but taking Rog's opinion it would make sense for each gauge to have a separate circuit and thus separate controller. Link to comment Share on other sites More sharing options...
Dosser16 Posted March 17, 2014 Author Share Posted March 17, 2014 Rog (RJ) said: You could if you wanted to but it may be better to have the DCC controller connected to one or the other, rather than having them both connected at the same time. Link to comment Share on other sites More sharing options...
Dosser16 Posted March 17, 2014 Author Share Posted March 17, 2014 Many thanks for your advice Link to comment Share on other sites More sharing options...
pidder Posted March 17, 2014 Share Posted March 17, 2014 Of course, if both tracks are powered by the one controller, each engine would have to have its own individual number...unless the controller is switched only to one or other of the tracks...now you're confusing me... Link to comment Share on other sites More sharing options...
RDS Posted March 17, 2014 Share Posted March 17, 2014 @Dosser16 Yes, you can connect a piece of N gauge track to the same controller and as long as you give your loco's different ID's, there is no reason why they will not both operate at the same time. There is no need to switch the supply from one track to the other - that is the beauty of DCC. Link to comment Share on other sites More sharing options...
Dosser16 Posted March 19, 2014 Author Share Posted March 19, 2014 Thanks again for your advice. Link to comment Share on other sites More sharing options...
