Yelrow Posted May 8, 2014 Share Posted May 8, 2014 hi, do the motors have to be the same make as the points, or can you pick and mix. I need 10 motors, and my need to eat outways somewhat inflated flebay prices, john Link to comment Share on other sites More sharing options...
Graskie Posted May 8, 2014 Share Posted May 8, 2014 Above or below board, yelrow? Certainly, if underneath, you can mix Hornby and Peco, as I have on my Peco pointwork. So, supposedly, it would work the other way round as well. Link to comment Share on other sites More sharing options...
Rog RJ Posted May 8, 2014 Share Posted May 8, 2014 yelrow said: hi, do the motors have to be the same make as the points, or can you pick and mix. I need 10 motors, and my need to eat outways somewhat inflated flebay prices, john Which points and motors are you thinking about using? Some point motors will fit directly to many different makes of points. Some will only fit to the same make of point. With some point motors you may have to devise your own method of mounting and connecting to the points. P3co surface mounted point motors can be used to operate Hornby points but Hornby surface mounted point motors (R8243) can't be used with P3co points because the hole in the Hornby point motor is too small to go over the pin of the throw-bar of P3co points. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted May 8, 2014 Share Posted May 8, 2014 I use Hornby motors with a wire push-rod extension, that fits anything, anywhere, providing it is more or less in line! Link to comment Share on other sites More sharing options...
Yelrow Posted May 8, 2014 Author Share Posted May 8, 2014 thank you gentlemen, for your response to date.I only have Hornby points, and saw on flebay, other brands of motors, used, in lots of 4/5. I can buy new hornby surface motors, from the liverpool store for £6, but know nothing about them, the motors, not the store. Graskie has forgotten my mounting problem, with ping pong table, so all have to be surface mounted, but i have seen, guagemaster, and another make, no longer in production. Trying to do this all on a shoe string, as budget very limited, john Link to comment Share on other sites More sharing options...
Graskie Posted May 8, 2014 Share Posted May 8, 2014 Sorry, John. Yes, I did forget that you're the ping pong man. I have a mounting problem as well nowadays. Sorry the Euro has devalued so much against the £ recently. Link to comment Share on other sites More sharing options...
RDS Posted May 8, 2014 Share Posted May 8, 2014 @yelrow I recently raised a thread under the General Discussion area called, 'What is your preference for Point Motors and Mounting' because I have found that the Hornby surface mounted point motors do not always operate the point completely, without removal of the spring (this is recognised by Hornby and mentioned in the instructions). I would prefer to use surface mounted because I tend to re-arrange my layout every few months because the modelling side of the Hobby does not really appeal to me, although I do like to see modelled layouts that other people have created. Link to comment Share on other sites More sharing options...
Yelrow Posted May 9, 2014 Author Share Posted May 9, 2014 RDS, as long as that, i am of a similar mind, and keep changing, on a weekly basis, at times. I enjoy landscaped layouts, but they are not for me, as i want continuous running, of as many tracks as possible., john Link to comment Share on other sites More sharing options...
Yelrow Posted May 9, 2014 Author Share Posted May 9, 2014 Graskie, when i bought my fermette, the euro was 0.51, so i was very happy. Yoday its 0.817, which is the best it has been for a long time. Last year, it was 1.09. . First thing i do each day, just to see if we can still afford to eat. john Link to comment Share on other sites More sharing options...
96RAF Posted May 9, 2014 Share Posted May 9, 2014 yelrow said: RDS, as long as that, i am of a similar mind, and keep changing, on a weekly basis, at times. I enjoy landscaped layouts, but they are not for me, as i want continuous running, of as many tracks as possible., john John If you wish to retain a measure of convenient changeability for your layout have you considered attaching a surface motor permanently to a point by way of say gluing a thin board (could be plastic or metal sheet) under the point with an extended part big enough to hang the motor on. You could use double sided tape for the attachment of both board and motor and even have a 3-way terminal block for easy wiring. Where a motor is difficult to install to a point that is close to another track you can as stated previously use wire extension rods (I have used large paper clips straightened and bent to shape for the job. You may have to clip the plastic link between sleepers to get them to pass through). Rob Link to comment Share on other sites More sharing options...
