gilbo2 Posted September 9, 2014 Share Posted September 9, 2014 Ran into my first issue when operating functions.Using 1.56 there now seems to be a delay between pressing the RailMaster grey function keys and it actually operating, eg lights f1. Delay does seem to change from a few ms to a second or more. This is a particular issue for my Loksound 4 decoders which have a tendancy to miss sound function requests altogther, eg horn. A standard R8249 has the same delay issues though.Any ideas? Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 9, 2014 Share Posted September 9, 2014 No changes have been made to the processing of loco function buttons in RailMaster 1.56. The delay sounds like it could be a communications issue between your PC and DCC controller. Have you also tried response times for loco speeds, shunting, cruise, stop etc?We have just tested a couple of sound locos and the functions respond nicely. Link to comment Share on other sites More sharing options...
gilbo2 Posted September 9, 2014 Author Share Posted September 9, 2014 Yes, can confirm delay is also present with loco operation itself (set CV 3/4 both to 0 to test).Something has changed somewhere as my 1.55 setup was fine. Any suggestions please? Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 9, 2014 Share Posted September 9, 2014 You should have received a reply to the Help Request you also sent a few minutes ago. Link to comment Share on other sites More sharing options...
gilbo2 Posted September 9, 2014 Author Share Posted September 9, 2014 I have had to go back to 1.55 to overcome my time delay problem as 1.55 still works fine. Be interesting if anyone else has this too. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 9, 2014 Share Posted September 9, 2014 Is there any lag in your points control too?It would be useful to know if anybody else does experience a lag when controlling locos and their functions in RailMaster 1.56 as we are unable to replicate this issue. Link to comment Share on other sites More sharing options...
gilbo2 Posted September 9, 2014 Author Share Posted September 9, 2014 Manual point operation is fine and from what I can tell program control fine too. (Have a really fast Tawcraft PAD decoder test program that still switches points every 0.1(ish) seconds.) Link to comment Share on other sites More sharing options...
RB51 Posted September 9, 2014 Share Posted September 9, 2014 Download of update speedy and all functionality seems fine. Certainly no time lag between requesting point change and subsequent throw. Now awaiting Pro upgrade code. R- Link to comment Share on other sites More sharing options...
gilbo2 Posted September 9, 2014 Author Share Posted September 9, 2014 The delay I'm seeing is when operating locos and functions. Points are OK. Link to comment Share on other sites More sharing options...
Mallard203 Posted September 9, 2014 Share Posted September 9, 2014 Nexus 7" no longer seems to support Zoom function, despite every effort (re-boots, etc). It is almost as screen is in two parts, active and passive - do I now have to toggle between them, and if so how?Loco selection works, but name of selected loco now obsures first row of function buttons, making it tricky to activate them.Handheld app is 1.20 (as expected) and Railmaster is 1.56. I do like the new skin. All locos defaulted to Reverse but setting tickbox in Railmaster fixed that. I looked in Railmaster.ini but couldn't see an obvious setting for Zoom on/off. I changed plan from mine to a basic sample but still no joy. When I try to zoom, track plan jumps about 1mm but refuses to zoom in. Almost impossible to switch points etc. Link to comment Share on other sites More sharing options...
St1ngr4y Posted September 9, 2014 Share Posted September 9, 2014 +Shows point/signal IDs at all zoom scales on main operating track planWhere you have points where the green button is on the left and the red button is on the right, at zoom level 75% or 50%, the point id obscures the red button so that you can't see it or press it! These are those points where the single track is nearest the top of the screen and the two branches are nearest the bottom of the screen i.e. like a Y which is upside down.I'm going to have to move a few signals around also, because their Id's can obscure nearby point buttons at 50/75% also.Ray Link to comment Share on other sites More sharing options...
Augustus Caesar Posted September 10, 2014 Share Posted September 10, 2014 At the mo I have a tes track and and have not much in the way of decoders added yet as my layout is under design and nearly ready to build.Having said that I experience no delays at all when throwing switches for points and no delays on loco lights either. I use an Acer V5 laptop with Win 8.1 (uuurrgghh - hate it) and no screen resolution issues either. Link to comment Share on other sites More sharing options...
Jailor Posted September 10, 2014 Share Posted September 10, 2014 Hope you have no work today looks like you need sleep after your night shift LOL. Link to comment Share on other sites More sharing options...
RB51 Posted September 10, 2014 Share Posted September 10, 2014 Can't seem to get the video to work. I got the "sucessfully downloaded" message, but thats it. R- Link to comment Share on other sites More sharing options...
RB51 Posted September 10, 2014 Share Posted September 10, 2014 Just adjusted CV29 on a loco (a couple of times) and I always "read" the current value before putting in the new one. After the read completes the window jumps "up" to it's opening position showing CV's 1 - 20 ish. Not a big thing. R- Link to comment Share on other sites More sharing options...
idlemarvel Posted September 10, 2014 Share Posted September 10, 2014 I think that was the same in 1.55. Annoying but as you say not a big deal. Link to comment Share on other sites More sharing options...
RB51 Posted September 10, 2014 Share Posted September 10, 2014 Ah - I havn't had much need to adjust that CV prior to today (when I've done it 3 times). Thanks. R- Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 10, 2014 Share Posted September 10, 2014 We will incorporate this in the next maintenance update. It is a relatively straightforward thing to do but has not been brought to our attention before. To clarify, if you have scrolled down the CVs window and then read settings (or write), RailMaster will remember the position and not start from the top row of the list again. Link to comment Share on other sites More sharing options...
Montywb Posted September 10, 2014 Share Posted September 10, 2014 For those odd creatures among us who actually read instruction manuals, the index to the guide needs updating - it's all over the place. Link to comment Share on other sites More sharing options...
RB51 Posted September 10, 2014 Share Posted September 10, 2014 Thanks - I'm impressed with the swift response, and embarassed that I didn't notice/say something in 1.55. R- Link to comment Share on other sites More sharing options...
Teedoubleudee Posted September 10, 2014 Share Posted September 10, 2014 Agreed. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 10, 2014 Share Posted September 10, 2014 The guide's index has been updated and should now automtacially be downloaded by RailMaster the next time you run the program.Sorry for any inconvenience. Link to comment Share on other sites More sharing options...
idlemarvel Posted September 10, 2014 Share Posted September 10, 2014 Minor glitch - if you have a screen less that 1024 pixels across (in my case 800 x 600 netbook) then if you edit a program you can't save it because the tick and cross icons in the bottom left are of the window not displayed - this was not the case in 1.55 - I can get around it because I can force the display into 1024x768 but I have to scroll the screen so a bit inconvenient. Link to comment Share on other sites More sharing options...
Montywb Posted September 10, 2014 Share Posted September 10, 2014 That's better. Thank you. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 10, 2014 Share Posted September 10, 2014 IdleMarvel, you really shouldn't be running RailMaster on an 800x600 netbook. That must be a very old machine - and probably underpowered too.RailMaster requires at least 1024x768, which in itself is very old and resolutions of all screens today are much higher than that.You may should invest in a machine with a higher resolution and can pick up a second hand notebook with at least a 1024x768 resolution for as little as £40-£50 on auction sites. Link to comment Share on other sites More sharing options...
