theflyingspanner Posted November 22, 2014 Share Posted November 22, 2014 since 1.58 up date the points dont always work i have to restart the progrwm any one else had this problem Link to comment Share on other sites More sharing options...
walkingthedog Posted November 22, 2014 Share Posted November 22, 2014 Hi theflyingspanner. You should have put this in the Railmaster section. RailMaster support monitor it and the Railmaster experts patrol it regularly. Link to comment Share on other sites More sharing options...
gilbo2 Posted November 23, 2014 Share Posted November 23, 2014 since 1.58 up date the points dont always work i have to restart the progrwm any one else had this problem I have had this a couple of times with 1.57 and then 1.58. Only way I could fix was to shutdown RM, unplug the eLink for 10 seconds and then start everything back up again. Link to comment Share on other sites More sharing options...
96RAF Posted November 23, 2014 Share Posted November 23, 2014 I found that if you manually select points quickly in sucession on screen eLink can lock up and an RM restart is the only way forward. Link to comment Share on other sites More sharing options...
gilbo2 Posted November 23, 2014 Share Posted November 23, 2014 I found that if you manually select points quickly in sucession on screen eLink can lock up and an RM restart is the only way forward. I find with that one that if I wait a few second (<30?) the system comes back to life. . I flagged this to HRMS over a year ago and the feedback was essentially to not click so fast, it is often easy though to do a double click by mistake and end up in this situation. Link to comment Share on other sites More sharing options...
