Pimm07 Posted November 23, 2014 Share Posted November 23, 2014 just converted most of my locos to dcc all are fine apart from my flying scotman, ive installed the hornby decoder, its fine without the tender but as soon as i put on the tender it shorts out and i get a message on the elink on my laptop telling me there is a short circuit any help would be much appreciated thanks in advance Link to comment Share on other sites More sharing options...
gilbo2 Posted November 23, 2014 Share Posted November 23, 2014 just converted most of my locos to dcc all are fine apart from my flying scotman, ive installed the hornby decoder, its fine without the tender but as soon as i put on the tender it shorts out and i get a message on the elink on my laptop telling me there is a short circuit any help would be much appreciated thanks in advance Is the Scotsman a DCC ready version, ie has it the 8pin decoder socket or have you had to solder the wires yourself? Link to comment Share on other sites More sharing options...
96RAF Posted November 23, 2014 Share Posted November 23, 2014 Looking at service sheet 316 for R2675 you must have hard wired your decoder as that shows it is loco driven but with a dummy ringfield motor in the tender and no decoder socket. I would check the loco drawbar assy as these are notorious for shorting on the tender post. Also check that the tender and loco connections are the same 'polarity' on the same side and the tender pickup is not cross connected versus the loco pickup. Link to comment Share on other sites More sharing options...
walkingthedog Posted November 23, 2014 Share Posted November 23, 2014 Did it work OK before the conversion? Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 23, 2014 Share Posted November 23, 2014 Given it is fine without the tender, and I'm assuming it worked before connection, I agree with RAF that the most likely cause is the tender draw bar connections. There are 2 little metal fingers there and I think you will find one is bent and shorting. Link to comment Share on other sites More sharing options...
john_pimm Posted November 28, 2014 Share Posted November 28, 2014 Did it work OK before the conversion? Yes it worked fine before the conversion had to run the old dc remote thing withe red knob it keeped shorting on the new type ones Link to comment Share on other sites More sharing options...
john_pimm Posted November 28, 2014 Share Posted November 28, 2014 Given it is fine without the tender, and I'm assuming it worked before connection, I agree with RAF that the most likely cause is the tender draw bar connections. There are 2 little metal fingers there and I think you will find one is bent and shorting. Thanks i will check that tomorrow will let you all know Link to comment Share on other sites More sharing options...
2e0dtoeric Posted November 29, 2014 Share Posted November 29, 2014 If you just put the tender on the track without the loco, do you still get the short circuit message? If you do, perhaps you have put one (or more) of the axles back in back to front. Link to comment Share on other sites More sharing options...
