Gazah Posted November 26, 2014 Share Posted November 26, 2014 Good afternoon all Do I need to do anything to the diamond crossovers R614 & R615 to use on a DCC layout, like add clips like I have done to convert my points? Link to comment Share on other sites More sharing options...
poliss Posted November 26, 2014 Share Posted November 26, 2014 Nope. Nothing. Link to comment Share on other sites More sharing options...
Gazah Posted November 26, 2014 Author Share Posted November 26, 2014 Nope. Nothing. Merci poliss Link to comment Share on other sites More sharing options...
Gazah Posted November 27, 2014 Author Share Posted November 27, 2014 Evening gents ok tried a crossover tonight and had a slight issue so 3 lines outer two connected via points to crossover middle line straight through crossover outer two work middle one does not, bear in mind not all track laid so no complete loop any suggestions? Link to comment Share on other sites More sharing options...
Yelrow Posted November 27, 2014 Share Posted November 27, 2014 Surely you will need to feed middle line, usually done with loop. Somebody will confirm, but just run another feed, unless i am missing something. It is past my bedtime in france. john Link to comment Share on other sites More sharing options...
RDS Posted November 27, 2014 Share Posted November 27, 2014 As John says, you need to feed the lines and this should be done automatically when you complete your loops. Link to comment Share on other sites More sharing options...
poliss Posted November 27, 2014 Share Posted November 27, 2014 The tracks in the crossover are completely electrically isolated from each other. Each one needs it's own power feed. Think of them like one track crossing the other via a bridge. Link to comment Share on other sites More sharing options...
Gazah Posted November 28, 2014 Author Share Posted November 28, 2014 The tracks in the crossover are completely electrically isolated from each other. Each one needs it's own power feed. Think of them like one track crossing the other via a bridge. Soooo if I used dropper cables to Bus wire this would then resolve the issue? Link to comment Share on other sites More sharing options...
Yelrow Posted November 28, 2014 Share Posted November 28, 2014 Yes, but once you have put in a bus, changing your layout, which we all do, turns your baseboard into woodworm. Just for now, run a pair of wires. Once yoyr totally happy with layout, ( if ever ), then put in your bus. john Link to comment Share on other sites More sharing options...
