PJ_model_trains Posted December 11, 2014 Share Posted December 11, 2014 Dapol track cleaning wagon, now fitted with Hornby 8 pin DCC chipWhat a good tool this is.I have only set it up and done a couple of short runs with the vacuum on, I thought it was clean, it picked up bits of static grass and other items I couldn't see.QUESTION to anyone who has one.What have you set cruise and shunt speeds to?I set it up as in train settings as a train name: Dapol track cleaning wagoncv 099Cruise and shunt speeds 40mph & 15mphDoes anyone know if these settings are correct?PJ Link to comment Share on other sites More sharing options...
RB51 Posted December 11, 2014 Share Posted December 11, 2014 My advice was to run at half speed - thats on DCC. R- Link to comment Share on other sites More sharing options...
Zues Posted December 11, 2014 Share Posted December 11, 2014 I would agree, Dapol say in their blurb its better to run at slow speed. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 11, 2014 Author Share Posted December 11, 2014 My advice was to run at half speed - thats on DCC. R- When setting the Dapol Track Cleaner wagon in Train settings list in RMI first set up CV 099I am then asked the cruise and shunt speeds, it is these speeds I am enquiring about.Not the speed of a train pulling the track cleaning wagon.I am on DCC Link to comment Share on other sites More sharing options...
Zues Posted December 11, 2014 Share Posted December 11, 2014 Can you not leave them at their default settings or do you have to put in settings for it to work, because all you are doing is adjusting the speed of the fan inside the cleaner. i have the same cleaner apart from doing the cv thing and naming it i have left everthing else at default levels, works a treat. Link to comment Share on other sites More sharing options...
Tee1707818014 Posted December 11, 2014 Share Posted December 11, 2014 My advice was to run at half speed - thats on DCC. R- When setting the Dapol Track Cleaner wagon in Train settings list in RMI first set up CV 099I am then asked the cruise and shunt speeds, it is these speeds I am enquiring about.Not the speed of a train pulling the track cleaning wagon.I am on DCCI think it depends on what accessory you are using at the time if using the vacuum then use the cruise speed at 35-40 but if using the buffer & polisher then, It needs to be slower so shunt at 15 - 20 would be more suitable. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2014 Author Share Posted December 12, 2014 My advice was to run at half speed - thats on DCC. R- When setting the Dapol Track Cleaner wagon in Train settings list in RMI first set up CV 099I am then asked the cruise and shunt speeds, it is these speeds I am enquiring about.Not the speed of a train pulling the track cleaning wagon.I am on DCCI think it depends on what accessory you are using at the time if using the vacuum then use the cruise speed at 35-40 but if using the buffer & polisher then, It needs to be slower so shunt at 15 - 20 would be more suitable. Hi tibrahimThat would make sense, I didn't want to set the settings to high.When I set it up in RM it didn't set th speeds, it left me to add them. I set at 15mph and 40mph but wondered if 40 was to high, hence my question on here.PJ Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2014 Author Share Posted December 12, 2014 I would agree, Dapol say in their blurb its better to run at slow speed.HiI did wonder if it was run the motor/fan in the track cleaner at low speed. Or run the train pulling the track cleaner at low speedPJ Link to comment Share on other sites More sharing options...
RB51 Posted December 12, 2014 Share Posted December 12, 2014 HiI did wonder if it was run the motor/fan in the track cleaner at low speed. Or run the train pulling the track cleaner at low speedPJ Good morning PJ - just want to make sure we are all on the same page. The decoder chip DCC ID you set up for the track cleaner only controls the speed of the "fan" in the cleaner, The speed of the loco pulling it is controlled using it's own DCC ID. If you stop the loco the fan keeps running until you stop that. I didn't enter any speeds for the track cleaner in the loco set-up page. I suppose you could make the track cleaner and loco up as a consist - but that might not be helpful. Was that your understanding? R- Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2014 Author Share Posted December 12, 2014 Hello RogerFirstly, yes the train has its own DCC chip and is set up as we do, my consideration is run the train slowly to have more chanceto pick up anything with the vacuum..Now the track cleaning wagon.The CV was set at 099I went to the train icon, set up locomotive. Set the CV to 099 but as it is not an Hornby item and not in the Train list it needed setting up manually.To complete the set up and save it needs the user to ad d the cruise and shunt speeds, this is where I put in 40 cruise, 15 shunt. But did wonder if 40 was to high.After saving, I control the train i the normal way in RM and run the track cleaner from the same area, having switched it on on the wagon first.PJ Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2014 Author Share Posted December 12, 2014 At first I got two speeds from the fan, slow and fast.Now I only get slow and wonder if 40mph was to fast?PJ Link to comment Share on other sites More sharing options...
RB51 Posted December 12, 2014 Share Posted December 12, 2014 Ah yes - I remember now. When I set my cleaner up I used an entry in the roster that was for a loco that I dont have any longer. So my cleaner became that loco if you like. It was a shunter so had 10 MPH for SHUNT and 30 MPH for CRUISE, but to be honest I dont use them I just push the throttle slider to around the halfway mark which is 20 MPH. Why you havn't got both settings now though is a mystery to me. The pamphlet says that too high a speed will melt the solder on the motor contacts. Surely then though you would have no motor at all. R- Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2014 Author Share Posted December 12, 2014 Oh dearMay be I need to open it and have a look but not got time today ;o(I only run it half way round one loop at 40mph then stopped it as I was concerned maybe speed to high at 40mphI think I will reset as a shunter first Link to comment Share on other sites More sharing options...
RB51 Posted December 12, 2014 Share Posted December 12, 2014 As you have one speed I think internally it should be OK. if the motor contacts had melted you wouldn't have any motor functionality at all. Maybe the decoder needs to be re-set? Just a thought. R- Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 12, 2014 Share Posted December 12, 2014 As you have one speed I think internally it should be OK. if the motor contacts had melted you wouldn't have any motor functionality at all. Maybe the decoder needs to be re-set? Just a thought. R-Has anyone mentioned yet that the Track Cleaner has its own overload protection built in. The motor will stop if it detects overheating. You then need to wait a few minutes to let it cool down again. So be aware of this in case you think it is a fault.Ray Link to comment Share on other sites More sharing options...
RB51 Posted December 12, 2014 Share Posted December 12, 2014 I wan't aware of that Ray, thanks for passing it on. If the overload protection had cut in though there would be no motor function at all I guess? R- Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2014 Author Share Posted December 12, 2014 As you have one speed I think internally it should be OK. if the motor contacts had melted you wouldn't have any motor functionality at all. Maybe the decoder needs to be re-set? Just a thought. R-Good point RogerThank you Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2014 Author Share Posted December 12, 2014 As you have one speed I think internally it should be OK. if the motor contacts had melted you wouldn't have any motor functionality at all. Maybe the decoder needs to be re-set? Just a thought. R-Has anyone mentioned yet that the Track Cleaner has its own overload protection built in. The motor will stop if it detects overheating. You then need to wait a few minutes to let it cool down again. So be aware of this in case you think it is a fault.Ray No one thought of this RayThank youStrange I am just getting the slow speed now?I will reset the decoder later and then set up as a shunter, I will leave an update once I have had chance to do so.Thanks for all your help guysPJ Link to comment Share on other sites More sharing options...
96RAF Posted December 12, 2014 Share Posted December 12, 2014 The cleaner wagon decoder only runs the Hoover fan/grinder/polisher motor so I set both shunt and cruise to 100. Setting up values for the traction unit is another thing. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2014 Author Share Posted December 12, 2014 The cleaner wagon decoder only runs the Hoover fan/grinder/polisher motor so I set both shunt and cruise to 100. Setting up values for the traction unit is another thing.Hi RAFSet shunt and cruise to 100 what mph? Have I misunderstood something here?PJ Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 13, 2014 Share Posted December 13, 2014 Whatever you do, don't set it to 100 Watts! I think he is saying run it flat out all the time PJ. Which makes sense as long as that doesn't lead to overheating. Why would you ever want to run the cleaner at a lower power? Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 13, 2014 Author Share Posted December 13, 2014 Whatever you do, don't set it to 100 Watts! I think he is saying run it flat out all the time PJ. Which makes sense as long as that doesn't lead to overheating. Why would you ever want to run the cleaner at a lower power? I ran it at 40mph and thought it sounded to fast so half way round stopped it.It has not run right since!!!!In the last hour I reset decoder cv8 to 8 then changed cv 3 to 99Result not good. I will have to open it, either motor runs slow or fan is slow or visa versa. I thought it had a cut out to stop over heating, someone else said this. I didn't think setting at 40 mph would be to high. I am now thinking eithor motor or fan has burnt out. I hope not but will find out. Link to comment Share on other sites More sharing options...
RB51 Posted December 13, 2014 Share Posted December 13, 2014 Hi PJ - what do you mean by "Result not good"? what happens now. R- Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 14, 2014 Author Share Posted December 14, 2014 Hi PJ - what do you mean by "Result not good"? what happens now. R-Hello RogerSomething is running inside, motor or fan? But slow speed only. I will need to open it to find out what.I reset the decoder CV 8 to 008, then changed item CV 003 to 099I train/loco set up I called up a shunter and set speeds at 20mph and 10mph.Then tested it, result not good! As above, something running but slow speed only.PJ Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 14, 2014 Share Posted December 14, 2014 Hi PJ - what do you mean by "Result not good"? what happens now. R-Hello RogerSomething is running inside, motor or fan? But slow speed only. I will need to open it to find out what.I reset the decoder CV 8 to 008, then changed item CV 003 to 099I train/loco set up I called up a shunter and set speeds at 20mph and 10mph.Then tested it, result not good! As above, something running but slow speed only.PJHi PJ,I assume the 20mph and 30mph apply to the loco which is pulling the track cleaner? But what speed are you running the track cleaner motor?Try experimenting with the track cleaner without a pulling loco, stationary in a siding until you are happy with the speed of the track cleaner motor. You can even take it off the track, stand it upside down and attach a set of crocodile clips between the wheels and track, then you will be able to see the fan rotating.Ray Link to comment Share on other sites More sharing options...
