PJ_model_trains Posted December 14, 2014 Author Share Posted December 14, 2014 Hi PJ - what do you mean by "Result not good"? what happens now. R-Hello RogerSomething is running inside, motor or fan? But slow speed only. I will need to open it to find out what.I reset the decoder CV 8 to 008, then changed item CV 003 to 099I train/loco set up I called up a shunter and set speeds at 20mph and 10mph.Then tested it, result not good! As above, something running but slow speed only.PJHi PJ,I assume the 20mph and 30mph apply to the loco which is pulling the track cleaner? But what speed are you running the track cleaner motor?Ray No RayWe are talking track cleaning motor speedsPJ Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 14, 2014 Share Posted December 14, 2014 Hi PJ - what do you mean by "Result not good"? what happens now. R-Hello RogerSomething is running inside, motor or fan? But slow speed only. I will need to open it to find out what.I reset the decoder CV 8 to 008, then changed item CV 003 to 099I train/loco set up I called up a shunter and set speeds at 20mph and 10mph.Then tested it, result not good! As above, something running but slow speed only.PJHi PJ,I assume the 20mph and 30mph apply to the loco which is pulling the track cleaner? But what speed are you running the track cleaner motor?Ray No RayWe are talking track cleaning motor speedsPJSo are you saying that 20 and 30 are the shunt and cruise speeds respectively for the track cleaner? And are these the speeds you are running it at? These seem low to me - I have my cruise set at 50mph.Ray Link to comment Share on other sites More sharing options...
RB51 Posted December 14, 2014 Share Posted December 14, 2014 No need to take it apart PJ - set it running and just remove the mesh cover in the middle. You might need a torch but you will see the fan part spinning in it's housing. There is no additional motor. What happens if you adjust the speed using the throttle slider rather than using the SHUNT and CRUISE buttons? R- Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 14, 2014 Share Posted December 14, 2014 PJ,May I ask why you set cv3 to 99? This is the acceleration rate i.e. the time it takes to get from stopped to, say, cruise speed. If you put this down to, say, 10, then try cruise speed, the motor should respond almost immediately to cruise speed.Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 14, 2014 Share Posted December 14, 2014 PJ,May I ask why you set cv3 to 99? This is the acceleration rate i.e. the time it takes to get from stopped to, say, cruise speed. If you put this down to, say, 10, then try cruise speed, the motor should respond almost immediately to cruise speed.RayAh hang on - now I understand. What you mean is that you changed the ADDRESS of the decoder from 003 to 099. You didn't change CV 3 at all.Ray Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 14, 2014 Author Share Posted December 14, 2014 PJ,May I ask why you set cv3 to 99? This is the acceleration rate i.e. the time it takes to get from stopped to, say, cruise speed. If you put this down to, say, 10, then try cruise speed, the motor should respond almost immediately to cruise speed.RayAh hang on - now I understand. What you mean is that you changed the ADDRESS of the decoder from 003 to 099. You didn't change CV 3 at all.RayYes RayI wrote CV8 = 008 which resets to manuf.settings thenThe Dapol wagon from CV003 to CV099Then added it to the list of trains to set the two speedsPJ Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 14, 2014 Share Posted December 14, 2014 PJ,I was confused because you seem to be using the term CV to mean the address of the decoder. CV stands for Configuration Variables, of which there are hundreds. They are referenced by the number of the variable, so for example, CV1 holds the ADDRESS of the decoder. When you say, CV003, that to me is a completely different thing.Ray Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 14, 2014 Author Share Posted December 14, 2014 PJ,I was confused because you seem to be using the term CV to mean the address of the decoder. CV stands for Configuration Variables, of which there are hundreds. They are referenced by the number of the variable, so for example, CV1 holds the ADDRESS of the decoder. When you say, CV003, that to me is a completely different thing.RaySorry for any confusion RayPJ Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 14, 2014 Author Share Posted December 14, 2014 Hi I have had the Dapol track clean wagon open! When I opened it a circular brass item dropped out, about 1/4" diameter and narrows looking like a plug (not the black one over the fuid compartment this is smaller and is brass) The switch and the chip were alright. I split it as far as I could without damaging any wires and could see the motor. The motor is over the fan and both turn they are not jammed or seized? At this stage as some dirt had come out and I was a little restricted I decided to put it back together and re-test. Sadly same as before a slow turning noise I can only assume is the motor asI couldn't see and there are no other electrical moving parts on the wagon to my knowledge. So, I wonder if the motor has damaged, I certainly wonder what the brass stopper is for and the leaflet that came with it only explains how to dismantle to fit or remove a DCC chip. Comment welcome from anyone who has one, has stripped one down, or has any ideas. Thank you PJ Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 14, 2014 Share Posted December 14, 2014 Put it back together and return it faulty under warranty PJ. Link to comment Share on other sites More sharing options...
RB51 Posted December 14, 2014 Share Posted December 14, 2014 The brass thing is what stops your cleaning fluid coming out in one big rush when you have filled the reseviour with IPA or similar. It creates a "drip" action onto the cleaning pad. Certainly sounds as though you may have a duff machine there - as Fishman says, return it for replacement. R- Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 14, 2014 Share Posted December 14, 2014 PJ,Do you have any of the attachments attached when you are running the motor i.e. the fan or a cleaning disc?Have you tried running it at 50 speed steps?Ray Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 15, 2014 Author Share Posted December 15, 2014 PJ,Do you have any of the attachments attached when you are running the motor i.e. the fan or a cleaning disc?Have you tried running it at 50 speed steps?RayHello RayOnly the fan for the vacuum.Are you referring to speed steps in the Cv's?I have only set shunt and cruise speeds as mentioned.PJ Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 15, 2014 Author Share Posted December 15, 2014 Put it back together and return it faulty under warranty PJ. Second hand auction! Link to comment Share on other sites More sharing options...
Zues Posted December 15, 2014 Share Posted December 15, 2014 Can you not temporarily change it back to DC to see if the fan runs as it should, it would eliminate the chip and safety switch/fuse etc from the equation. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 15, 2014 Author Share Posted December 15, 2014 Can you not temporarily change it back to DC to see if the fan runs as it should, it would eliminate the chip and safety switch/fuse etc from the equation.Hello ZuesI only have DCC with RailMaster I will take it all to bits another day and have another look. I need to find where the brass plug has come out also. Thanks for your commentsPJ Link to comment Share on other sites More sharing options...
RB51 Posted December 15, 2014 Share Posted December 15, 2014 Good morning PJ - I get the feeling that you are missing some posts - or just choosing not repsond to some of us. I have pointed out what the brass plug is for (it goes in the bottom of the cleaning fluid chamber and is loose - it does not attach to anything) and I have asked you to look at the fan blades with the mesh centre piece off (with a torch) and I have asked you what happens if you try to adjust the speed using the throttle slider instead of the SHUNT and CRUISE buttons. As far as I can see you have not responded to my questions. I can keep saying these things but I'm sure other readers are getting bored with the repitition. R- Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 15, 2014 Author Share Posted December 15, 2014 Good morning PJ - I get the feeling that you are missing some posts - or just choosing not repsond to some of us. I have pointed out what the brass plug is for (it goes in the bottom of the cleaning fluid chamber and is loose - it does not attach to anything) and I have asked you to look at the fan blades with the mesh centre piece off (with a torch) and I have asked you what happens if you try to adjust the speed using the throttle slider instead of the SHUNT and CRUISE buttons. As far as I can see you have not responded to my questions. I can keep saying these things but I'm sure other readers are getting bored with the repitition. R- Hello Roger No I have not missed the messages just created a task list to check all the items mentioned then answer once I have done so. I picked up on the brass plug going in the bottom of the chamber but didn't realise it remains loose. I was going to see where it went and check the other items when I open it up. hence the reason I have not replied yet. Thank you for your concen and for your help. I will be back once I have checked your suggestions. ;o) I am sure readers will now understand. To satisfy my wife that I am not always in my engine shed, she thinks I should live there, many of these messages are not done near my layout or trains. PJ Link to comment Share on other sites More sharing options...
96RAF Posted December 15, 2014 Share Posted December 15, 2014 It's a Hoover. If you want to pick up stuff it needs to run flat out. If you use it as a grinder/polisher run it a bit slower else it will throw the wagon off the track and may even flip your points over depending upon motor direction. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 15, 2014 Author Share Posted December 15, 2014 It's a Hoover. If you want to pick up stuff it needs to run flat out. If you use it as a grinder/polisher run it a bit slower else it will throw the wagon off the track and may even flip your points over depending upon motor direction.Hi RAFThat was why I thought 40mph speed setting was not to fastPJ Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 15, 2014 Share Posted December 15, 2014 PJ,Do you have any of the attachments attached when you are running the motor i.e. the fan or a cleaning disc?Have you tried running it at 50 speed steps?RayHello RayOnly the fan for the vacuum.Are you referring to speed steps in the Cv's?I have only set shunt and cruise speeds as mentioned.PJHi PJ,Nothing to do with cv's. I have the shunt and cruise speeds set to 10 and 50 respectively, and I only use cruise, irrespective of whether I am using the fan or the "grinder". The fan is much quieter than the grinder.Ray Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 16, 2014 Author Share Posted December 16, 2014 Hello Roger and Ray I have started to strip the wagon down but keep getting interuptions, wife at hospital today her turn! I will get back to it soon but meanwhile I thought I would share this reply from another forum... Have you had a short circuit? If so, you may have melted the solder that holds one of the springs connecting the pickups to the motor wiring. As explained in the instructions, this is intentional in order to protect the motor from excessive current because it is only a 9volt motor. On it's first run I did get a short at the far end of the layout but, it cut out immediately!!!He also said... I posted a thread in the Dapol section some time ago in which I said I believed the product was not fit for purpose. Dapol actually sells a kit of replacement parts but it involves soldering them on - and there are several. I sent mine back to the supplier for a refund and bought instead a small, mains powered vacuum cleaner designed for vacuuming the interior of cars. I have found it very easy to use; it is supplied with a shoulder strap so, on a larger layout, you can still reach the distant track and it comes with a range of tiny attachments that appear to be just made for 00 gauge. It is a Draper and cost about £50 - rather less than the Dapol track cleaner plus decoder and postage. I do also have the CMX machine but that does not have a vacuum function. Unfortunately I purchased in an auction on that fleabay site, under the distance selling Regs. you have no come back in an auction. Expensive mistake! That will teach me not to 'dapol' in the auctions! PJ Link to comment Share on other sites More sharing options...
RB51 Posted December 16, 2014 Share Posted December 16, 2014 I would wait to see if that is the case before deciding you have made a mistake. If it is just melted solder can you not just re-solder it? I confess to not having looked inside yet so that might be a daft thing to say - see what is wrong and see if you can recover it. R- Link to comment Share on other sites More sharing options...
Yelrow Posted December 16, 2014 Share Posted December 16, 2014 PJ, i have exactly the same item, which i keep for DC only. The problems you have had, have only occurred, since its conversion. As was said before, why cant you return it to DC, and test. Do you not have a battery charger or another 12 volt supply. If it bench tests ok on DC, that will prove it was fine on purchase. That being the case, you could either sell it on ebay, or re convert.. The other comment made about fit for purchase, on another forum, is rubbish. The amount the vacuum picks up, is unbeliveable. Its a great little machine. Would not be without it john Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 16, 2014 Author Share Posted December 16, 2014 I would wait to see if that is the case before deciding you have made a mistake. If it is just melted solder can you not just re-solder it? I confess to not having looked inside yet so that might be a daft thing to say - see what is wrong and see if you can recover it. R- Hello Roger I agree, I had started to take it apart but will have to wait until my wife gets home to continue. I got as far as boggie wheels off and am ready to start on opening the body work but phone and door bell keep causing interuptions and with two 6 month old kittens that are like missiles I have to be caeful. They haven't got in my engine shed yet, but they want to and I can't move very fast. ;o) PJ Link to comment Share on other sites More sharing options...
