96RAF Posted December 17, 2014 Share Posted December 17, 2014 The Ali bridges are a good idea TL23. A good basis for an open frame trackbed.Note to Apple - I have turned off predictive text so why does my iPad still keep writing spellings I didnt type. Link to comment Share on other sites More sharing options...
wayne_nicholls Posted December 18, 2014 Author Share Posted December 18, 2014 Yes, a reversing loop, counting from the right, the fourth and sixth sets of points are the problem.If you take the right turn at the fourth point, go up the gradient, round, over the top, and down again, where the green engine is, you will see that it has swapped directions.What you need to do is fit a reversing module to the high level loop, and insert two isolating breaks into the track, one by the green engine, and one just past the fourth point, before the climb starts.Problem solved. I hope you intend supporting that high-level track better than that! Link to comment Share on other sites More sharing options...
wayne_nicholls Posted December 18, 2014 Author Share Posted December 18, 2014 Thanks guys, a reverse loop it is then!and by means of track support, I'm still building, trials, the layout is only 8ft by 4ft, support brackets will be widened, etc. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 18, 2014 Share Posted December 18, 2014 Hi Wayne, Have you run your trains and carriages up to ensure they can cope with the incline? Remove a section of track to test, until you get a reverse loop module, best to test as you are building. PJ Link to comment Share on other sites More sharing options...
ModelerXYZ Posted December 20, 2014 Share Posted December 20, 2014 It is a reverse loop. Use plastic fishplates and you should have no problems. What the others said about gradients is true, tesst with a train. they don't take too well to going upstairs to the next level. Link to comment Share on other sites More sharing options...
Graskie Posted December 20, 2014 Share Posted December 20, 2014 They can come down fast enough, but, yes, it's getting them up there in the first place. I use mainly diesels on my incline, although a couple of double-headed steam locos might be able to get up there, something I haven't actually tried yet. Just another "to do" on my list. Very easy to find out, though! Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 20, 2014 Share Posted December 20, 2014 XYZ - plastic fishplates on their own are no good.If you think about it, all you have done is make a crude switch, (the gap in the track) with the metal train wheels as the contact!As soon as a wheel bridges the gap, you have another short circuit.A long, totally isolated, section is needed, with plastic fishplates at BOTH ends, further apart than the longest possible train, and the reversing module providing power to the section. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 20, 2014 Share Posted December 20, 2014 Wayne, you now have 4 pages of replies, confirmations from 5 of us and your photos, telling you just what was suggested in the first 3 replies on page 1 of this thread. Not trying to say I told you so, just noting it was all explained, including a link to more info on Brian Lambert, in those replies. To summarise the whole lot in one sentence: you have an RL and you must put in it a section longer then your longest train isolated at both ends on both rails with IRJs and you need to switch the polarity of this section as trains enter and leave using an RLM to do it automatically, or manually with a DPDT break before make switch. Adding some clarification: the switch solution is very much inferior to the RLM and I would only use it as a temporary measure if you can't afford the RLM immediately. You will most certainly make one or more mistakes with a switch and short out your layout. And the RLM will only work reliably if you are using a 4 Amp supply, not the 1 Amp that comes with Select and eLink. So if you don't already have the 4, you will need to buy it when you buy the RLM. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted December 20, 2014 Share Posted December 20, 2014 XYZ - plastic fishplates on their own are no good.If you think about it, all you have done is make a crude switch, (the gap in the track) with the metal train wheels as the contact!As soon as a wheel bridges the gap, you have another short circuit.A long, totally isolated, section is needed, with plastic fishplates at BOTH ends, further apart than the longest possible train, and the reversing module providing power to the section.There is a reason I use DC again. but you are right, It does need to be totally isolated. at both ends. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 21, 2014 Share Posted December 21, 2014 Even dc won't work with an uninsulated reversing loop!If you only have one insulated break, as the loco passes over the break, it will try to go both ways at once! Link to comment Share on other sites More sharing options...
wayne_nicholls Posted January 2, 2015 Author Share Posted January 2, 2015 /media/tinymce_upload/IMG_1318.jpg Link to comment Share on other sites More sharing options...
wayne_nicholls Posted January 2, 2015 Author Share Posted January 2, 2015 hi, ive just uploaded an image of my layout, ive brought an Reverse Loop Module, and i still cant get it to work.Can someone please explain simply where to put the two power connecters from the RLM,or if it will work.I dont think its a tear drop loop as it goes up on track 3 and comes back on track 4. Link to comment Share on other sites More sharing options...
wayne_nicholls Posted January 2, 2015 Author Share Posted January 2, 2015 Gap?, what gap?, sorry but i dont understand! Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 2, 2015 Share Posted January 2, 2015 Gap made by the IRJ. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 2, 2015 Share Posted January 2, 2015 hi, ive just uploaded an image of my layout, ive brought an Reverse Loop Module, and i still cant get it to work.Can someone please explain simply where to put the two power connecters from the RLM,or if it will work.I dont think its a tear drop loop as it goes up on track 3 and comes back on track 4. Wayne, it is a teardrop RL. The rest of the circuit is your crossover between tracks 3 and 4. Link to comment Share on other sites More sharing options...
wayne_nicholls Posted January 2, 2015 Author Share Posted January 2, 2015 Gap made by the IRJ.Sorry, but whats an IRJ? Link to comment Share on other sites More sharing options...
poliss Posted January 2, 2015 Share Posted January 2, 2015 IRJ = Insulated Rail Joiner. Like the metal ones, but made from plastic. Also called fishplates. Link to comment Share on other sites More sharing options...
wayne_nicholls Posted January 2, 2015 Author Share Posted January 2, 2015 IRJ = Insulated Rail Joiner. Like the metal ones, but made from plastic. Also called fishplates.Ok, Thanks, so where do i put these IRJ? Link to comment Share on other sites More sharing options...
poliss Posted January 2, 2015 Share Posted January 2, 2015 At both ends of the reverse loop. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 2, 2015 Share Posted January 2, 2015 I explained where the reversing loop was in my post on page 3, about halfway down. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 2, 2015 Share Posted January 2, 2015 Put your IRJs at the start of your incline for one end, and the end of your decline at the other. The input of your RLM goes anywhere you like outside the isolated RL section, and the output anywhere inside the isolated section. It is the only power source to the isolated section and switches the polarity to match that outside the loop as a train crosses over either entering or leaving the loop. And remember, it will only work reliably if you are using the 4 Amp supply on your DCC controller. Link to comment Share on other sites More sharing options...
