william maxwell Posted March 11, 2015 Share Posted March 11, 2015 Can anyone help.I received a Mixed Freight Dcc set for Christmas.It can with track pack A.I have been using this since and it is great.Last week I purchasedctrack packs B and C. I made this into a double loop and pluged in transformer.Nothing happened except transformer makes clicking noise and flashes what appears to be I C.Both loops wok on their own but when points are added nothing!I am at a complete loss as this is my first set. Link to comment Share on other sites More sharing options...
Yelrow Posted March 11, 2015 Share Posted March 11, 2015 William, hi, welcome to the forum. This is the set with the select controller, i belive. Firstly, have you fitted all points with the little dcc point clips. They would have come , with the original set, but NOT, with Packs B And C. You have to buy them seperately. If this is the case, remove all points, not modified, join track up just as you can, and try it. Should then be fine. You can buy packs of 20 clips from ebay. Others will give you a far more technical explanation, about DCC, but without point clips, it wont run. john Let me know how it goes. Link to comment Share on other sites More sharing options...
poliss Posted March 11, 2015 Share Posted March 11, 2015 Have you used link wires or used a second power feed? Link to comment Share on other sites More sharing options...
william maxwell Posted March 11, 2015 Author Share Posted March 11, 2015 William, hi, welcome to the forum. This is the set with the select controller, i belive. Firstly, have you fitted all points with the little dcc point clips. They would have come , with the original set, but NOT, with Packs B And C. You have to buy them seperately. If this is the case, remove all points, not modified, join track up just as you can, and try it. Should then be fine. You can buy packs of 20 clips from ebay. Others will give you a far more technical explanation, about DCC, but without point clips, it wont run. john Let me know how it goes.Yes I have point clips fitted to all points.when I join track points spark Link to comment Share on other sites More sharing options...
william maxwell Posted March 11, 2015 Author Share Posted March 11, 2015 Have you used link wires or used a second power feed?I tried using link wires that came with pack C no luck.I haven't used a second power feed just select controller Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 11, 2015 Share Posted March 11, 2015 There is a short-circuit somewhere, that comes into play when the points connect the loops. It is difficult to picture what is happening, and why, without being able to see the layout. Link to comment Share on other sites More sharing options...
william maxwell Posted March 11, 2015 Author Share Posted March 11, 2015 There is a short-circuit somewhere, that comes into play when the points connect the loops. It is difficult to picture what is happening, and why, without being able to see the layout.Could it be incorrect fitting of fishplates? Link to comment Share on other sites More sharing options...
poliss Posted March 11, 2015 Share Posted March 11, 2015 I'm wondering if the points may be faulty. Do you have a multimeter? Link to comment Share on other sites More sharing options...
Yelrow Posted March 11, 2015 Share Posted March 11, 2015 Take out points one at a time, rejoin track. When problem re occures, you have found offending point, john Link to comment Share on other sites More sharing options...
william maxwell Posted March 11, 2015 Author Share Posted March 11, 2015 I'm wondering if the points may be faulty. Do you have a multimeter?I don't but I have a gaugemaster track tester Link to comment Share on other sites More sharing options...
william maxwell Posted March 11, 2015 Author Share Posted March 11, 2015 Take out points one at a time, rejoin track. When problem re occures, you have found offending point, johnMany thanks I will try that thank you. Link to comment Share on other sites More sharing options...
poliss Posted March 11, 2015 Share Posted March 11, 2015 The track tester won't work for the test I have in mind, which is to put one probe on a rail and see if there's continuity on one of the other rails, where there shouldn't be any.This could be caused by the connections underneath the rails not being insulated or wired properly. Link to comment Share on other sites More sharing options...
william maxwell Posted March 11, 2015 Author Share Posted March 11, 2015 Take out points one at a time, rejoin track. When problem re occures, you have found offending point, johnSorted! Did that and found one point not working.Looks ok it's one that came with the set! many Many thanks for that Link to comment Share on other sites More sharing options...
william maxwell Posted March 11, 2015 Author Share Posted March 11, 2015 The track tester won't work for the test I have in mind, which is to put one probe on a rail and see if there's continuity on one of the other rails, where there shouldn't be any.This could be caused by the connections underneath the rails not being insulated or wired properly.Took out the points and tried them one at a time found one causing the problem.Replaced it and all well.How can a new point be faulty? Link to comment Share on other sites More sharing options...
Yelrow Posted March 11, 2015 Share Posted March 11, 2015 My post now seems to have disappeared. Rteurn the point to shop or hornby for replacement. john Link to comment Share on other sites More sharing options...
RB51 Posted March 11, 2015 Share Posted March 11, 2015 John, your post is at the bottom of page 1. R- Link to comment Share on other sites More sharing options...
william maxwell Posted March 11, 2015 Author Share Posted March 11, 2015 My post now seems to have disappeared. Rteurn the point to shop or hornby for replacement. johnWill do thank you once again Link to comment Share on other sites More sharing options...
poliss Posted March 11, 2015 Share Posted March 11, 2015 Admin. If this is a batch of faulty points, which from what others say it could be, then this is a problem for everyone, not just DCC users. Link to comment Share on other sites More sharing options...
