robert_cooper Posted February 17, 2017 Share Posted February 17, 2017 Has the ARC Pro been dropped? Link to comment Share on other sites More sharing options...
Blagard Posted February 17, 2017 Share Posted February 17, 2017 No it is part of the 2017 range "Expected: Winter 2017" The only issue with that publication is the number of times it has failed to do as expected. Hopefully this time it will happen. Link to comment Share on other sites More sharing options...
Andy P. Posted February 18, 2017 Share Posted February 18, 2017 Thanks for your interest. I suggest you use the search function to the right and you will find a thread dsicussing ARC PRO and what to expect.Thanks Link to comment Share on other sites More sharing options...
Blagard Posted February 19, 2017 Share Posted February 19, 2017 I noticed in another thread the ARC Pro platinum set and it is listed as expected Autumn 2017. So that is the same as Q4 2017 a tad earlier than Winter 2017 which I believe starts on 21 Dec 2017 One other thing I noticed was that the cars are DPR which is important because it means instead of factory fitted chips the cars should have the Digital modules that can be transferred to other cars. One downside of early digital sets was the factory fitted chips which means you could not easily transfer them to a new car if for one reason or another the car got broken with the chip intact. Link to comment Share on other sites More sharing options...
