2e0dtoeric Posted March 27, 2017 Share Posted March 27, 2017 I posted a photo and short description of my home-brew track cleaning car, on Sunday at about 1800.Normally my images appear immediately, but this time both the image and text were 'held for moderating'.They still have not appeared, so I have posted a replacement, which appeared immediately.So - there must be a gremlin in the system that is eating posts! Link to comment Share on other sites More sharing options...
RB51 Posted March 27, 2017 Share Posted March 27, 2017 You are not alone 2e0 - there does seem to be an intermittent problem. One of my posts with an image was delayed for approval. R- Link to comment Share on other sites More sharing options...
96RAF Posted March 27, 2017 Share Posted March 27, 2017 Ditto - posts and images just failed to post and it wasnt due to a logout either as I,was still in After the failed to appear event. Has anyone with an iPad noticed that recently the keyboard is middle of screen and covers what I am typing about.Rob Link to comment Share on other sites More sharing options...
RB51 Posted March 27, 2017 Share Posted March 27, 2017 No Rob. Keyboard at bottom of screen here in sunny Spain. I am on my IPad. R- Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 27, 2017 Author Share Posted March 27, 2017 Using a 'real' desktop 'puter. Link to comment Share on other sites More sharing options...
walkingthedog Posted March 27, 2017 Share Posted March 27, 2017 Keyboard in the same place as always, section you type in is lower. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted March 27, 2017 Share Posted March 27, 2017 I'm gonna be pedantic and say my keyboard is on my desk... 😛I've got a proper putey you see... 😛 😛Seriously though... does seem a tad odd that some are experiencing these minor issues and others not. Having said that it may be a system problem and not down to the forum... folk's settings may differ from others on their machines. Just a thought... Link to comment Share on other sites More sharing options...
96RAF Posted March 27, 2017 Share Posted March 27, 2017 I've had a look in all my iPad settings and can't see why it should place itself where it does, so I'll file it in the same category as why some pictures I posted on the pannier tank sound thread have disappeared and there are only placeholders. Maybe an iPad reset is required. Here's a screen grab of the keyboard problem... /media/tinymce_upload/b2aac407a057781c2800e912dfc75a2a.PNG Link to comment Share on other sites More sharing options...
walkingthedog Posted March 27, 2017 Share Posted March 27, 2017 That's very odd, it really has moved up. Wierd. Link to comment Share on other sites More sharing options...
walkingthedog Posted March 27, 2017 Share Posted March 27, 2017 Tap and hold hide keypboard key, bottom right. When menu appears select 'undock' then you can slide keyboard up and down by holding hide keyboard key. Do as above and select 'dock' on menu, keyboard stays at the bottom. Link to comment Share on other sites More sharing options...
96RAF Posted March 27, 2017 Share Posted March 27, 2017 @WTD I can't get that tap and hold menu to appear but the keyboard has gone to the screen bottom again after going onto other forums and then coming back here. Most odd... Rob Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 27, 2017 Share Posted March 27, 2017 Impressive WTD. Had the grandkids around helping again? Link to comment Share on other sites More sharing options...
walkingthedog Posted March 27, 2017 Share Posted March 27, 2017 @WTD I can't get that tap and hold menu to appear but the keyboard has gone to the screen bottom again after going onto other forums and then coming back here. Most odd... RobYou need to switch on 'split keyboard' in Settings - General - Keyboard. Link to comment Share on other sites More sharing options...
walkingthedog Posted March 27, 2017 Share Posted March 27, 2017 Impressive WTD. Had the grandkids around helping again?Very amusing Fishy. I looked it up on Yahoo. 😆 That's what it is for. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted March 28, 2017 Share Posted March 28, 2017 I remember this one from a client a couple of years back since my last post in this thread... Anyway Rob, here's an addition to the find made so far by our good friend... Using the keyboard icon and pressing hold to pop up the dock/split sometimes does not work.Try this: Go to Settings > Keyboard and find the button for "split keyboard". If it is switched ON simply turn it OFF.I also believe that a simple drag of the keyboard to the bottom will dock it... unless the split keyboard switch is on maybe? This last point I am totally sure of but it is food for thought. Link to comment Share on other sites More sharing options...
walkingthedog Posted March 28, 2017 Share Posted March 28, 2017 I said that in the post above my last one AC. 😆 Link to comment Share on other sites More sharing options...
96RAF Posted March 28, 2017 Share Posted March 28, 2017 @WTD I can't get that tap and hold menu to appear but the keyboard has gone to the screen bottom again after going onto other forums and then coming back here. Most odd... RobYou need to switch on 'split keyboard' in Settings - General - Keyboard. Thanks WTDI found the split keyboard selection and toggled it without knowing what it actually did and that is why the keyboard mysteriously reverted to normal again.Rob Link to comment Share on other sites More sharing options...
walkingthedog Posted March 28, 2017 Share Posted March 28, 2017 It comes to something when I give advice about computers/ipads RAF. It must be a sign or something. 😆 Link to comment Share on other sites More sharing options...
Augustus Caesar Posted March 28, 2017 Share Posted March 28, 2017 Oops.... so you did WTD.I probably scrolled too quickly past the two posts you made back to back and spotted only one of them.Note to oneself... take my time and look hard before repeating other member's texts and trying to nick the credit 😳 😮At least Rob used your fix and not mine ay? 😎 Link to comment Share on other sites More sharing options...
walkingthedog Posted March 28, 2017 Share Posted March 28, 2017 Hey AC you probably saw my name and thought I'll ignore that he hasn't got a clue about computers, you'd have been right 😆 Link to comment Share on other sites More sharing options...
