Kenneth ONeill Posted March 21, 2019 Share Posted March 21, 2019 Well, I built the Airfix B-26 back when it was a new release, bomb bay open, and rather than trying to ballast it used the included and designed for purpose ladder as a prop. Link to comment Share on other sites More sharing options...
T2B Posted March 21, 2019 Share Posted March 21, 2019 Yes if memory serves me correctly from when I built a couple in the long and distant past, the ladder fits onto the main spar running along the bottom of the bomb bay and acts to support the tail heavy beast in the correct position on it's nose wheel, however to accomplish this the bomb bay is required to be displayed open. For the closed bomb bay option, some weight would still be required but you could use the bomb bay space so long as you kept the weight forward of the pivot point (e.g. the main under-carriage legs)! Link to comment Share on other sites More sharing options...
Peter s Posted March 21, 2019 Share Posted March 21, 2019 Yes if memory serves me correctly from when I built a couple in the long and distant past, the ladder fits onto the main spar running along the bottom of the bomb bay and acts to support the tail heavy beast in the correct position on it's nose wheel, however to accomplish this the bomb bay is required to be displayed open. For the closed bomb bay option, some weight would still be required but you could use the bomb bay space so long as you kept the weight forward of the pivot point (e.g. the main under-carriage legs)!The main wheels are peculiarly far forward compared to other aircraft (level with bomb bay) I'm wise to this after a P38 tail sitter . The kit i built has a bulkhead behind the cockpit and another in front of the bomb bay (I'm sure it's the radio / navigator room) loads of space for weight in there. I'm sure the Airfix is similar. Link to comment Share on other sites More sharing options...
Whisperhead Posted May 30, 2019 Share Posted May 30, 2019 I've had a few surprises with tail-sitters (looking particularly at you, Me262) but the first few times it happened I had already near-finished the models! One reasonable tip I was given is to use a small piece of spare sprue and attach it underneath as a stanchion, somewhere hidden... But have since learned from the mistake! Link to comment Share on other sites More sharing options...
