Carter11 Posted April 4, 2020 Share Posted April 4, 2020 Before purchasing an ARC set, im wondering if the track pieces from my current Scalextric Sport circuit set, will be compatible with the pieces with the ARC set so that i have extend the circut, i have some cars that already have digital plugs in them though. Link to comment Share on other sites More sharing options...
gorp Posted April 4, 2020 Share Posted April 4, 2020 Arc track uses scaly sport as the basic track.You CANNOT use your current powerbase, powerpack, and controllers while using the Arc powerbase, powerpack, and controllers. Arc one and air follow same track building rules as your current set. Arc pro ( depending on version you get and any mods done by you) allows more versatility on digital side. BUT Arc pro analog side follows same analog building rules as your current set , so it really depends on what kind of racing you want and how much you want to spend. Link to comment Share on other sites More sharing options...
Andy P. Posted April 6, 2020 Share Posted April 6, 2020 All Sport tarck is comptabile with ARC and all digital sets.You can use the "brake mod" to combine ARC ONE and a regular set. It will void your warramty though. Link to comment Share on other sites More sharing options...
