peterz Posted April 19, 2012 Share Posted April 19, 2012 2e0dtoeric said: I may be totally wrong on this, as my railway is still under construction, and I haven't powered up my Elite yet, so hopefully someone will jump in and put us all right - but doesn't the Elite require a four digit code to re-programme a chip - ie zero zero zero four? The elite will display four zeros initialy,and automaticaly "move along" as you enter numbers,so that four digits are always displayed, therefore I don't see any problem. Link to comment Share on other sites More sharing options...
Vetran 22 Posted February 2 Share Posted February 2 Again on the program problem. All my engines program fine except my (only 1) Heljan 33 bought from Rails of Sheffield fitted with their decoder. On test track it says 17 after program but only runs on 03? Link to comment Share on other sites More sharing options...
P-Henny Posted February 2 Share Posted February 2 @Vetran.I can't see the point of resurrecting a near 12 year old thread. Particularly as this is the OP's only post since 2012, so he is not likely to see your comment. Link to comment Share on other sites More sharing options...
LTSR_NSE Posted February 2 Share Posted February 2 I think @Vetran is actually asking for help with programming their loco! Possibly they have an Elite & simply picked an existing thread that looked related?@Vetran on this forum it is advisable to start your own thread if seeking help & only add to existing ones if you are offering advice or merely commenting on previous posts. 😀 Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 2 Share Posted February 2 It’s very rare that anyone who jumps on the end of old threads actually has the same problem as was discussed initially.In this instance, the OP is having problems programming 8215s with an Elite at its firmware revision 1.4 when current is 1.45. 1.45 is a very different beast to 1.4. And the Heljan/ROS decoder will certainly not be an 8215.Vetran, standard advice is to first reset the decoder by writing 8 to CV8 then try writing the address you want again. Tell us how you go.If you still have problems after trying this, we will need to know the firmware version of your Elite and the make and model of decoder in the loco to give you more assistance. Link to comment Share on other sites More sharing options...
