Richo193 Posted May 20, 2020 Share Posted May 20, 2020 I recently purchaed the Ford GT40 and whenever it leaves the track the guide blade/brush assy leaves the car. It has a different setup to the otherr cars in that the assembly is a push fit, which seems quite secure, but isn't in a crash. Anyone have any adviceor tips? Cheers Link to comment Share on other sites More sharing options...
gorp Posted May 21, 2020 Share Posted May 21, 2020 Your ford gt is from the first decade of this century.It is designed to pop guide out to change braid and held guide better than 90s style.There should be a clip inside that holds guide but hard accidents can pop it out and sometimes is not fully pushed back in.The next generation of guides have a changable round braid section that can slide off track and cause power problems when left uncorrected. Link to comment Share on other sites More sharing options...
Richo193 Posted May 21, 2020 Author Share Posted May 21, 2020 Your ford gt is from the first decade of this century.It is designed to pop guide out to change braid and held guide better than 90s style.There should be a clip inside that holds guide but hard accidents can pop it out and sometimes is not fully pushed back in.The next generation of guides have a changable round braid section that can slide off track and cause power problems when left uncorrected. Thanks for that, the guide comes out even when it just slides off the track, guess I'll just have to drive slower! Cheers Link to comment Share on other sites More sharing options...
gorp Posted May 21, 2020 Share Posted May 21, 2020 You could take body off and see what is going on inside.And you could try a different guide. Link to comment Share on other sites More sharing options...
Andy P. Posted May 21, 2020 Share Posted May 21, 2020 The plates with the braids have a top, bottom, front and back.Make sure they are inserted the "correct" way and that should help. Link to comment Share on other sites More sharing options...
