21 pin blank plug
7576737
Hi, Just acquired 3 Riv Re4/4s HR2100 x 2, + HR 2058). All have decoders but I may want to return them to analog for a time. Does anyone know where I can get the correct plugs for these models? I've tried Bachmann 21 pin blanks but most of the lococ lighting is lost when they're fitted!
As with any blanking plate if you have a soldering iron then you can bridge any of the pins to reinstate the services you require.
All you need is the 21-pin MTC standard to refer to and a few bits of link wire, plus of course your soldering iron if you want the links to be permanent and reliable.
  • 3 weeks later...
