Westcountry Posted September 23, 2020 Share Posted September 23, 2020 Any thoughts on whether it is best to buy an A3 or A4 typr loco?! Many thanks Link to comment Share on other sites More sharing options...
Forum-1211528 Posted September 24, 2020 Share Posted September 24, 2020 It doesn't really matter because they all look the same. I would buy the Flying Scotsman set (if you can find it) because you can see all the Traction rods moving on it. Link to comment Share on other sites More sharing options...
96RAF Posted September 24, 2020 Share Posted September 24, 2020 GoWest will tell you exactly what the differences are between the two chassis and if one is better than the other in basic form. Ken has extensively modified these chassis for his diverse fleet of live steamers and his build progress reports on this forum show the ins and outs of why a particular chassis was chosen. These posts of his make very good reading for anyone taking up live steam as they show the workings in detail and point out the problems and subsequent fixes. Link to comment Share on other sites More sharing options...
gowest Posted September 24, 2020 Share Posted September 24, 2020 Hi Westcountryi like the name?Rob's comments have put me on the spot but over the years I have built a few engine and in doing so found the things I like about the different typesFirst there are 3 engines built by Hornby they are the A4's and the 2 A3's the early one and the late one Buying second hand is always a problem and you might get a good engine or a bad engine how they have been used and if enough oil or after care has been carried out to keep them in good order as these engines like the full size engine need more care before and after a run.So any of the range that Hornby made are ok and will be a good buy if the seller can tell you that it's condition is good with no faults.the A4's are a straight live steam engine the only point to watch are does it have the vacuum pipe on the front buffer beam and coupling hook other things to Look for are the handbrake control in the tender and water scoop handle this will also apply to the A3's plus on A3's check the front steps are not broken off just behind the front buffer beam.if possible take a look at the front wheel boggy set sub frame base if it has had very little use the paint on the under side will be in good order if the engine has been run loads of time the paint here will be scratch down to the cast meatal base.i think the best of the range from an engineering point of view is the last of the A3's this engine has a good oil control system and can be listed as the only A3 with a removable chimney but really nothing to choose from the range they are are all good fun and give hours of fun never two runs are the same so it will be your choice at the end of the day that matters and if you need it Hornby and J H can sort out any problems you might have.ken Link to comment Share on other sites More sharing options...
Westcountry Posted September 25, 2020 Author Share Posted September 25, 2020 Hi, thanks for the advice - will let you know how I get on! Have acquired an unused control set still in original packaging including shipping box!! Link to comment Share on other sites More sharing options...
gowest Posted September 25, 2020 Share Posted September 25, 2020 Westcountrylets hope your control units are in tip top condition you will have to wait till you get an engine to check both controller and engine out.keep us informed if you can.ken Link to comment Share on other sites More sharing options...
96RAF Posted September 26, 2020 Share Posted September 26, 2020 Apologies for putting you on the spot Ken, but we all know you are defInitely the best man to answer the question. Link to comment Share on other sites More sharing options...
