HM6000 PWM settings.
Roger1707821911
Each circuit can be so adjusted individually via Edit Devices in Settings.
Also covered in the full user manual.
Be aware that if running a decoder fitted loco using this system, you may got odd responses if you fiddle with the PWM Freq setting.
DC locos are fine and generally respond per the video review.
I haven’t tried it with a core-less motor yet as I don’t have one.
First issue was 2.2 second interval breaks in the sound.
Thanks Roger.
That issue is under investigate but at day’s end may not be fixable in the HM|DC app as I am told that latency is a well known android audio fault likely requiring an update to each android device firmware.
