Arc Pro PB LED Board
MashaFX
  • 1 year later...
My lights are on dim or not at all. Have some issues at times programing a car. But all that are programed run just fine and that is 200 +cars. Issue arises if I by a new car or loose the id in a bad crash or short. I have disconnected the unit and reconnected I have power jumps to properly supply power around the track. So not knowing what I have missed.
  • 2 weeks later...
Hi Paul,
There is a FFC style ribbon cable which connects the LED/button panel to the main circuit board. If some LEDs and buttons are not working, most likely this cable is not seated correctly. There are surface mount sockets at both ends.
If you have electronics repair skills you could open up the powerbase and re-seat the cable at both ends. Note there are release tabs on each socket.
If you don’t have the necessary skills or if it’s still in warranty, a return to Hornby for repair would make sense.
Hope that helps.
c
