simon-543318 Posted December 24, 2022 Share Posted December 24, 2022 I am fairly new to scalextric and have over the past 12 months been expanding my collection of cars and increasing the size of the track .The biggest problem I have with some of the new cars are they are not gliding that well ,they seem to be too deep .Do I need to adjust the blade by taking a small amount off it with sand paper or something ,bit baffled as most of them work perfectly well on the same track .Would very much appreciate some advice . Simon Link to comment Share on other sites More sharing options...
Martin-345304 Posted December 27, 2022 Share Posted December 27, 2022 Are you using the newer Sport track or the original version? The older tracks grove is not so deep and would affect the running of newer cars which have a deeper guide blade. Link to comment Share on other sites More sharing options...
Andy P. Posted December 28, 2022 Share Posted December 28, 2022 Yes.. what Matin said... what type of track are you using? Link to comment Share on other sites More sharing options...
roguejackal Posted December 28, 2022 Share Posted December 28, 2022 Sounds like you are using some Scalextric classic track and some of the cars have the slightly deeper guides, if this is the case you may need to trim a little off the guide if you are planning to keep your circuit or track? Link to comment Share on other sites More sharing options...
simon-543318 Posted December 29, 2022 Author Share Posted December 29, 2022 Thank you for your replies ,yes the track is fairly new ,about 10 years old with the slot in connection ,and I although I have some of the old classic track I don`t use much of it . Perhaps if I adjusted the braid and trim a bit off the blade. Link to comment Share on other sites More sharing options...
Andy P. Posted December 30, 2022 Share Posted December 30, 2022 Could it be you are ot using Hornby cars?Other brands have longer and deeper guide blades that do often need trimming in order to work on newer Sport track... Link to comment Share on other sites More sharing options...
simon-543318 Posted December 31, 2022 Author Share Posted December 31, 2022 No,its only about 5 new ones of different makes Ninco ,Scalextric and Carrera . Link to comment Share on other sites More sharing options...
Andy P. Posted January 1, 2023 Share Posted January 1, 2023 Well all the non-Hornby cars will have deeper, wider guide blades that will "slow! them down.The Carrera cars have VERY strong magnets and that will make them also much slower.Otherwise regular car maintenance will help>https://uk.scalextric.com/community/advice/car-maintenancehttps://uk.scalextric.com/community/advice/track-maintenance Link to comment Share on other sites More sharing options...
