Ian-364932 Posted August 20, 2023 Share Posted August 20, 2023 Hi, returning modeller from 40+ years ago.Wondered which air brush & compressor make would modellers on here recommend ?Never had them back in the day so new to it all.I don't mind spending money to get a decent one as i’d like to do a good job on my build.Many thx Link to comment Share on other sites More sharing options...
peebeep Posted August 20, 2023 Share Posted August 20, 2023 You'll get dozens of different recommendations, my own picks would an AS186 compressor (with reservoir) and one of the Fengda airbrushes, the latter are cheap as chips but are really quite reasonable quality. You should find the compressor on Amazon or eBay for under £100. If you're prepared to spend a bit more on the airbrush the Gunze Sanyo range of Procon airbrushes are outstanding. Go for a top cup/gravity feed. Link to comment Share on other sites More sharing options...
Topcat_Ern Posted August 21, 2023 Share Posted August 21, 2023 I echo what is said. My advice is also get the compressor with a tank. One without runs continuously and gets very hot. The Fengda brushes are very good and I would suggest the ones where the nozzles can be removed without tools as they are much easier to clean with less chance of damage. So good I have three, one at 0.5 (for 1/35 kits), one at 0.3 and one at 0.2 (unfortunately screwed nozzle). In fact they are so easy I have put my Iwata Neo back in its box and away in the cupboard.Andy Link to comment Share on other sites More sharing options...
Ian-364932 Posted August 21, 2023 Author Share Posted August 21, 2023 Thx for that.will check them out 👍🏻 Link to comment Share on other sites More sharing options...
Sam Murray Posted September 11, 2023 Share Posted September 11, 2023 Are there any downsides to having an airbrush with an integrated compressor? Link to comment Share on other sites More sharing options...
Topcat_Ern Posted September 14, 2023 Share Posted September 14, 2023 Are there any downsides to having an airbrush with an integrated compressor? Not sure what you mean there Sam, can you elaborate or give an example? Andy Link to comment Share on other sites More sharing options...
