Steve-353799 Posted September 11, 2023 Share Posted September 11, 2023 Hi guys Does Itrain recognise Railmaster as a command station/interface?thanks steve Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 11, 2023 Share Posted September 11, 2023 Itrain is an alternative system to RM. I don’t believe either will recognise the other. It doesn’t even list Select, Elite or eLink as compatible controllers. Link to comment Share on other sites More sharing options...
P-Henny Posted September 11, 2023 Share Posted September 11, 2023 Railmaster and iTrain are both software. I think the question you are probably asking is does iTrain software recognise Railmaster's eLink track interface and the answer is no.Although some non Hornby software will recognise Hornby's Elite controller, nobody has yet got any other non Railmaster commercial software to recognise an eLink.Ray's DIY software previously discussed in your other threads recognises an eLink, but this is because Ray has 'back engineered' the interface protocol in the eLink USB sub-system. Link to comment Share on other sites More sharing options...
96RAF Posted September 11, 2023 Share Posted September 11, 2023 eLink as stated uses a unique handshake with RM which precludes general use with other applications.I tried it with Rocrail in the early days and got odd results, every command was sent several times and none actioned. Link to comment Share on other sites More sharing options...
