Precision Poly Cement
Sometimes the glue dries in the needle applicator. When this happens I remove the needle, hold it in a pair of tweezers and run a flame form a cigarette lighter along the needle. Sometimes there is a little flare as the glue burns out. You should be very careful when doing this, of course. Having cleared the needle the glue will flow freely without having to squeeze the bottle.
HTH
It's important to cover the needle again with the cover provided the minute you are through applying the glue. Never let it stand about uncovered or the problem will happen again and again.
PS: I don't mean cover it at the end of your modelling session .....I mean cover it each and everytime you apply the glue to a part.
