Rick-372992 Posted November 21, 2023 Share Posted November 21, 2023 Does anyone have experience of using the R8247 Accessory Decoder to activate relays? If so I would appreciate seeing a wiring diagram to connect the 8 R8247 permanently on outputs to e.g. 12v 8 channel relay board (using Railmaster). Link to comment Share on other sites More sharing options...
96RAF Posted November 21, 2023 Share Posted November 21, 2023 Yes - see here for details which also includes manual switching and use of a CDU. Image shows rotary switches and push buttons but any manual switching can be deployed in lieu.Also have a read of this where I look at using various relay modules with an acc decoder. Be aware the notations on the images could be better (another round tuit job).http://www.halton96th.org.uk/relay-module.htmlIf you intend to use the relays to switch a constant load then set the acc decoder ports to always on. Obviously not if you intend to fire solenoid points. Link to comment Share on other sites More sharing options...
P-Henny Posted November 21, 2023 Share Posted November 21, 2023 Two of the 8 relays will need to be used per R8247 port.The operate coil of relay 1 would wire to the R8247 port 1 C & + terminals.The operate coil of relay 2 would wire to the R8247 port 1 C & - terminals.The operate coil of relay 3 would wire to the R8247 port 2 C & + terminals.The operate coil of relay 4 would wire to the R8247 port 2 C & - terminals.EtcThus operating R8247 port 1 for right & left would operate Relays 1 & 2 and operating R8247 port 2 for right & left would operate Relays 3 & 4The four C terminals of the R8247 are commoned together internally and is a permanent positive DC polarity. The + & - terminals on the R8247 are both switched negative polarity, including the + terminal which is not denoting positive.Note this though.The default output for the R8247 is pulse output. This will pulse the relays. If you need the relays to lock on, you will need to configure the R8247 port for 'always on'.The default pulse configuration would be ideal to use the relay board relay contacts to operate Solenoid points using a traditional external CDU point operating solution. This is the function of my relays used with my R8247s to overcome the weak internal CDU output of the R8247. I am also using Railmaster.EDIT: 96RAF posted whilst I was still typing mine.P.S Using 'All Capitals' in forum etiquette is considered 'shouting' and should be avoided if possible. You might consider trying to edit your thread title via the 3 dot edit menu option, that is if a mod doesn't edit it for you in the meantime.Mod Edit: ‘tis done Link to comment Share on other sites More sharing options...
Rick-372992 Posted November 22, 2023 Author Share Posted November 22, 2023 Thank you both for your speedy and helpful responses! Link to comment Share on other sites More sharing options...
