Hornby 9F sound fitted.
Colin-378485
If a model actually has a sound decoder fitted, this will control both sound & motion (no other decoder required.)
DCC Ready is the opposite of DCC Fitted and merely means the product has a socket into which a decoder can be plugged, but the decoder is a separate purchase.
Hornby’s website unfortunately contains several pieces of conflicting, contradictory and inaccurate information - so it is always worth double checking exactly what product you are actually purchasing!
Edit - for the reasons @RDS states, in this instance ‘DCC Fitted’ is the accurate info & ‘DCC Ready’ is inaccurate and to be ignored!
I actually have this model and yes it is ready to go. The only thing you might want to do is update the sound to the latest level. The give away is the price, 9Fs are expensive but not that much without sound. In fact the 9F with sound is really good value for money, the 9Fs retail price is £252.99, so you are getting the sound option that retails for over £60 for less than £30. The only thing that isn't included is the Powerbank but because the 9F has so many pickups, you don't need it.
Might want to update the sound profile?
Definitely update the sound profile. There have been many improvements made to the sound profiles since this was fitted at the factory, particularly around reliable running. you should treat the update as mandatory.
There is a table in the stickies at the top of the HM | DCC forum that tells all the latest versions.
