Rallymatt Posted March 2 Share Posted March 2 (edited) Looking at pic, I would imagine fitting a PB would require a little more disassembly. Taking the motor cover off; section with the fan mounted on as it is probably too close fitting to allow the PB fly lead to sit on top and the body go back on. Appears to only be 4 screws that are easily accessible, so not too difficult. The Guards area does look to have some space but if it’s a bit tight for a PB, there is a way to make the PB more ‘size adaptable’ for tighter spaces, I’ll pop a post up over weekend 😁 Edited March 2 by Rallymatt Spilling Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 1 minute ago, Rallymatt said: Looking at pic, I would imagine fitting a PB would require a little more disassembly. Taking the motor cover off; section with the fan mounted on as it is probably too close fitting to allow the PB fly lead to sit on top and the body go back on. Appears to only be 4 screws that are easily accessible, so not too difficult. The Guards area does look to have some space but if it’s a bit tight for a PB, there is a way to make the PB more ‘size adaptable’ for tighter spaces, I’ll pop a post up over weekend 😁 I think it will fit on its side at the bottom. Will take the power car apart and take a side on pic. You maybe right though.. 1 Link to comment Share on other sites More sharing options...
GMD Posted March 2 Share Posted March 2 @Dodge1965 and @RallymattThanks for the info - if they are indeed now designing the new releases with the full HM7000 experience in mind (BT, Sound and PB) I think that's a really good sign of integrated thinking. We can then hopefully assume on this being replicated in future releases. Link to comment Share on other sites More sharing options...
Tim Allen Posted March 2 Share Posted March 2 The Mk3 coaches have arrived. Looks like the decoder in the dummy car has died, no lights or sound and not connected in app... 1 Link to comment Share on other sites More sharing options...
Rallymatt Posted March 2 Share Posted March 2 Coaches look great Tim. Just check the decoder I fully seated into the socket and the pick ups on the Dummy Power Car are contacting ok. Actual decoder failures are quite rare, but they can happen. 😁 Link to comment Share on other sites More sharing options...
GMD Posted March 2 Share Posted March 2 Wow - @Tim Allen - that looks awesome. Love the close coupling. And thanks for showing a comparative length photo. Have a feeling I may have left some of my scenery clearances a little tight for that length. Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 (edited) On 29/02/2024 at 15:18, Postman On The Rails said: There is loads of space for stay alive, side ways is too tight, length way is much better. Cable is plenty long enough to reach connection. Edited March 2 by Dodge1965 1 Link to comment Share on other sites More sharing options...
Tim Allen Posted March 2 Share Posted March 2 20 minutes ago, Rallymatt said: Coaches look great Tim. Just check the decoder I fully seated into the socket and the pick ups on the Dummy Power Car are contacting ok. Actual decoder failures are quite rare, but they can happen. 😁 looks like the decoder, reseated and nothing. Put the blank back in and lights came on. This'll be the 3rd failure for the decoders. 1st one burnt out (literally melted), Blink Bonny just stopped on a straight and now this one today. It was working perfectly with the reds and engine sounds but then I noticed lights were off. I'll contact customer services (again). Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 Driver and mate added while apart.. 4 Link to comment Share on other sites More sharing options...
Rallymatt Posted March 2 Share Posted March 2 12 minutes ago, Tim Allen said: looks like the decoder, reseated and nothing. Put the blank back in and lights came on. This'll be the 3rd failure for the decoders. 1st one burnt out (literally melted), Blink Bonny just stopped on a straight and now this one today. It was working perfectly with the reds and engine sounds but then I noticed lights were off. I'll contact customer services (again). Might be worth checking power supplies etc to prevent any further damages. So many failures seems more than a coincidence and yet all the HM DCC decoders currently were from same batch. Link to comment Share on other sites More sharing options...
Rallymatt Posted March 2 Share Posted March 2 @Dodge1965, thanks for the pic showing space for a PB if wanted and looks so much better with people. Which range are they from? I must do some crew in my locos 😁 1 Link to comment Share on other sites More sharing options...
Rallymatt Posted March 2 Share Posted March 2 37 minutes ago, GMD said: Have a feeling I may have left some of my scenery clearances a little tight for that length. You need to break out the ‘Modellers Axe’ Greg 🤣 Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 1 hour ago, Tim Allen said: The Mk3 coaches have arrived. Looks like the decoder in the dummy car has died, no lights or sound and not connected in app... Wow @Tim Allen those coaches look amazing.. Lovely to see some pics and someone using them.. DPD should deliver mine soon... I Hope.. Loving seeing all the updates on the HST. Will be even better when the other two are out and pics are up.. Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 14 minutes ago, Rallymatt said: @Dodge1965, thanks for the pic showing space for a PB if wanted and looks so much better with people. Which range are they from? I must do some crew in my locos 😁 Haha i funny man... They also have their two dogs with them, they are laying on the floor alseep.. Probably against the rules !!! Men are from here https://www.moorviewmodels.co.uk/ Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 2 Share Posted March 2 57 minutes ago, Dodge1965 said: Driver and mate added while apart.. They look like their on a blag lol 1 Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 3 minutes ago, Postman On The Rails said: They look like their on a blag lol Bag!! Air ride self levelling seats that I installed for them… don’t u know🤣 Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 2 Share Posted March 2 2 minutes ago, Dodge1965 said: Bag!! Air ride self levelling seats that I installed for them… don’t u know🤣 Aren’t we all posh 😝 Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 Just now, Postman On The Rails said: Aren’t we all posh 😝 I look after my workers! 1 Link to comment Share on other sites More sharing options...
taunmarc88 Posted March 2 Share Posted March 2 @Dodge1965 The intercity looks amazing I’m enjoying watching you all get to grips with them! I don’t know if I will get one so I’m living through everyone who did right now! Link to comment Share on other sites More sharing options...
Skelton Junction Posted March 2 Share Posted March 2 Rails received their allocation late yesterday. 😊 Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 55 minutes ago, taunmarc88 said: @Dodge1965 The intercity looks amazing I’m enjoying watching you all get to grips with them! I don’t know if I will get one so I’m living through everyone who did right now! Its sure is.. Blown me away the quality and the sound... Very happy bunny right now, If i can do anything else for you, please let me know... Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 55 minutes ago, Skelton Junction said: Rails received their allocation late yesterday. 😊 Great news... So hopefully early next week then? Link to comment Share on other sites More sharing options...
Rallymatt Posted March 2 Share Posted March 2 1 hour ago, taunmarc88 said: @Dodge1965 The intercity looks amazing I’m enjoying watching you all get to grips with them! I don’t know if I will get one so I’m living through everyone who did right now! Snap 😁; great to see another superb model making people happy! Excited for people 👍 3 Link to comment Share on other sites More sharing options...
Generic Hornby Username Posted March 2 Share Posted March 2 11 hours ago, StuLarge said: I do hope that doesn't happen to the Blue version 🤞🏼🤞🏼🤞🏼 https://uk.hornby.com/products/br-class-43-hst-digital-train-pack-era-7-tt3021txsm Agreed! That's the version I've got on a preorder. As @Moccasin mentioned, I think we should be good! 1 Link to comment Share on other sites More sharing options...
Dodge1965 Posted March 2 Author Share Posted March 2 2 minutes ago, Generic Hornby Username said: Agreed! That's the version I've got on a preorder. As @Moccasin mentioned, I think we should be good! They would have removed this by now, but do we really know why the HST digital version was canned? Link to comment Share on other sites More sharing options...
