Alanburford9101 Posted February 29 Share Posted February 29 Hi I have an Evening Star loco where the wheels just spin with no traction at all. Is this just a case of worn tyres? Alan Link to comment Share on other sites More sharing options...
LTSR_NSE Posted February 29 Share Posted February 29 Since you mention traction tyres, is it a tender drive model? If yes: Disconnect loco from tender & then gently push loco, does it freewheel smoothly & easily? or are the wheels very stiff, or even locked up? If loco freewheels easily (but tender tyres still spin) - then yes they need replacing. If loco wheels are stiff/stuck - then this needs addressing first, (tyres may still need replacing) but you won’t know that until loco is running properly. Link to comment Share on other sites More sharing options...
Alanburford9101 Posted February 29 Author Share Posted February 29 Ok thanks. I will check later. Thanks. Alan Link to comment Share on other sites More sharing options...
Alanburford9101 Posted February 29 Author Share Posted February 29 Yes, the loco wheels had got stuck. Dont know why all of a sudden. But she is running perfectly now. Thanks for your help. Alan 2 Link to comment Share on other sites More sharing options...
Simmo009 Posted February 29 Share Posted February 29 Alan, what is the R number? Link to comment Share on other sites More sharing options...
Alanburford9101 Posted March 1 Author Share Posted March 1 How can I find the R number? Link to comment Share on other sites More sharing options...
atom3624 Posted March 1 Share Posted March 1 Does it have a box? Is it 'tender drive' - motor in tender and actual locomotive wheels just free-running - turning as the loco is pushed along? Is it 'loco drive' - drive is direct to the 10 locomotive driving wheels? Does it have a 'pin and fingers' connection for the drawbar between the locomotive and tender - and they are easily separated? Is the tender connected to the locomotive with a metal drawbar - screw at both ends - with a 2- or 4-cable white micro plug which plugs into the tender? Al. Link to comment Share on other sites More sharing options...
