Ratch Posted April 15 Share Posted April 15 Initially I washed the runners in warm, soapy water. I then did some research into the aircraft. I had the H type on my Wanted List for one of those flown from Harrington in Northamptonshire during World War II. From August 1943, specially modified Liberators were used on classified missions, codenamed ‘Carpetbaggers’. The missions involved sending commando units and spies (called Joes/Josephines) into occupied Europe prior to the invasion. No 801 (Provisional) Bomb Group was stationed at Harrington in Northamptonshire. 36, 406, 788, and 850 Squadrons formed the 801st carrying out these missions. Their B-24s were painted with a glossy black, anti-searchlight paint, with nose and waist guns and ball turret removed. A ‘Joe Hole’ was used in place of ball turret. Waist windows were blacked out and teardrop blisters added to both cockpit windows. Post-invasion they flew gasoline in to Patton’s tanks. My list of aircraft that flew from Harrington is as follows: 42-95036, 42-52767, 42-51124, 42-51187, 42-95317, 42-40474, 41-28871 ‘The Leading Lady’, I have photos of 42-52711 ‘Screwball’, and 42-51211 Y “Miss Fitts”. I am leaning towards 42-52711 ‘Screwball’, though I don’t have much photographic evidence of the appearance of any aircraft. Turning to examine the instructions, the opening steps involve assembly of the cockpit. Link to comment Share on other sites More sharing options...
Ratch Posted April 16 Author Share Posted April 16 I made a list of the internal components to be airbrushed and selected Vallejo Model Air 71094 Green Zinc Chromate. It occurred to me that the interior may have been re-painted black to match the exterior, but I have no evidence for either colour. I brushed the propeller tips with Humbrol Acrylic Dropper Bottle DB0024 No. 24 Trainer Yellow – Matt. Link to comment Share on other sites More sharing options...
Ratch Posted April 17 Author Share Posted April 17 I painted detail on the cockpit and dipped the transparencies in Klear. Decals were applied for the instruments. I have made up the ordnance, it will be going in to the bomb dump. Link to comment Share on other sites More sharing options...
Ratch Posted April 18 Author Share Posted April 18 I was not going to fit the bomb sight (B16) but considered that it may have been used on clandestine missions. F6 appears to be an ammunition feed for the nose turret. I know that this turret was not used to save weight, so I made some alterations. The instructions call for 25g to be added behind the instrument panel bulkhead. I don’t know what Paramjit used, but I could only squeeze 13g of lead weight into the space. I fear a tail-sitter on my hands. I had two large ejector pin lugs on part #A7, a bulkhead, which needed tidying up. Step 14 addresses another compartment where 30g is supposed to be inserted. Once again, I could not get anywhere near that weight in, and cramming my aquarium weights into the void distorted the assembly. This is obviously not a good thing. We have learned that any misfitting parts will have dire consequences later in the build. Link to comment Share on other sites More sharing options...
Ratch Posted April 19 Author Share Posted April 19 One thing I don’t like about this kit design is the excessive gates, which enter the mouldings on two edges. This makes cleaning up arduous, and absolutely necessary to ensure the correct fit. I appreciate that ideally the gate should be wide enough to ensure a free flow into the mould. I do like the detail in these sub-assemblies. Almost little models in their own right. I wonder what colours the bomb bay area and rear part of the fuselage are supposed to be. I suspect the bomb bay should be aluminium (bare metal), and the rear part Zinc Chromate Yellow, but I have painted them in the Vallejo colours converted on the Airfix table from the Humbrol paints specified on the instruction sheet. I’m not that bothered as everything will be buttoned up and I doubt that any of the interior will be seen. I’m treating it as painting practice. Link to comment Share on other sites More sharing options...
Tour de Airfix Posted April 20 Share Posted April 20 On 18/04/2024 at 18:43, Ratch said: I don’t know what Paramjit used, but I could only squeeze 13g of lead weight into the space. I’ve built four 1:72 scale B-24 Liberators over the past years and all have ended tail-sitters. Minicraft, Academy and a couple of the original Airfix kits. I did attempt to fill the nose of last Academy kit with sufficient lead to overcome this but, unbelievably, the nose wheel collapsed under the weight. I eventually removed the lead when structural faults started to appear where the nose joined the fuselage! The Airfix kit came with a crew ladder installed at the rear which when lowered was intended to keep the tail off the ground. I have heard rumour that something similar had to be used on the tail of the real aircraft and that it was most stable when loaded with bombs! 1 Link to comment Share on other sites More sharing options...
Tour de Airfix Posted April 20 Share Posted April 20 On 15/04/2024 at 17:32, Ratch said: I had the H type on my Wanted List for one of those flown from Harrington in Northamptonshire during World War II. From August 1943, specially modified Liberators were used on classified missions, codenamed ‘Carpetbaggers’. What a great idea. Having one of these in my stash I’m really enjoying following your build. 👍 Like you, my plan is to do something different. I have in mind building it as one of the Special Ops Liberators from 223 (Bomber Support) Squadron, 100 Group which took part in the Electronic War. I’ve still got quite a bit of research to complete first. 1 Link to comment Share on other sites More sharing options...
Ratch Posted April 22 Author Share Posted April 22 I tested out my new airbrush with Vallejo Model Air 71062 Aluminium on a few parts. A little splutter to start but it sprayed nice and evenly and will certainly do for broad-brush spraying. I then set about assembling the interior. Link to comment Share on other sites More sharing options...
Ratch Posted April 23 Author Share Posted April 23 I airbrushed aluminium over specific parts in readiness for the next assembly steps. It looks like the fuselage joining will be a bit tight. Link to comment Share on other sites More sharing options...
Ratch Posted Friday at 18:30 Author Share Posted Friday at 18:30 Work on the interior has continued. Link to comment Share on other sites More sharing options...
paul71 Posted Saturday at 10:11 Share Posted Saturday at 10:11 enjoying watching this ratch looks like there is plenty of detail in it, think i will be getting one at some point 1 Link to comment Share on other sites More sharing options...
Ratch Posted yesterday at 17:17 Author Share Posted yesterday at 17:17 Thanks Paul. Some more info on the Carpetbagger Liberators. The oxygen equipment was removed, and plywood flooring fitted to aid movement of supplies. Gee British hyperbolic navigational aids were fitted though these were later updated to Loran US equipment. Rebecca/Eureka equipment was also used. Before joining the fuselage, I added a plywood panel over the Joe Hole. As expected, I’m having serious trouble getting the fuselage to meet. Link to comment Share on other sites More sharing options...
Tour de Airfix Posted yesterday at 20:05 Share Posted yesterday at 20:05 2 hours ago, Ratch said: As expected, I’m having serious trouble getting the fuselage to meet. Is that because of your interior mods or have you hit on a challenge with the new moulding? Link to comment Share on other sites More sharing options...
Ratch Posted yesterday at 20:09 Author Share Posted yesterday at 20:09 All the new toolings are a very tight on tolerances. A layer of paint can affect the fit. I have yet to work out how to avoid it other than not to paint internal stuff. Link to comment Share on other sites More sharing options...
Ratch Posted 4 hours ago Author Share Posted 4 hours ago The gaps looked really bad, but when filled with plastic putty they are less noticeable. The tail went together much easier. Link to comment Share on other sites More sharing options...
