Griswald Posted April 29 Share Posted April 29 Hi I have a Eurostar which I can’t use because the drive wheels cog is worn and i cannot believe spares are not available for something that’s prone to wear Link to comment Share on other sites More sharing options...
dBerriff Posted April 29 Share Posted April 29 https://www.petersspares.com/index.jsp?pg=2&searchStr=eurostar Link to comment Share on other sites More sharing options...
Going Spare Posted April 29 Share Posted April 29 @dBerriff - Those parts are for the Jouef/Hornby HO-scale Eurostar. Drive bogie wheelsets and even the complete drive bogie for the 00 version have not been available for some while. @Griswald - I would make your complaint direct to Customer Services at Hornby as they do not routinely monitor forum posts. Link to comment Share on other sites More sharing options...
Deem Posted April 30 Share Posted April 30 (edited) Hello Griswald I just googled now and I don't know if these are the same wheel set you need, double check before you order and this website is showing in stock. https://www.theparishs.uk/product/eurostar-complete-wheel-axle-set/ I hope that is helpful to you. Sorry my mistake, When I click on add or buy it now, it took me to Hornby website where item is out of stock. Edited April 30 by Deem Link to comment Share on other sites More sharing options...
ntpntpntp Posted April 30 Share Posted April 30 If the genuine spares aren't available, maybe look at 3rd party gears (eg. for radio control models, robotics etc.). Are they axle gears on wheelsets where a wheel can be removed with a worm/gear puller tool to get to and change the gear? I do this quite often with older N gauge locos where spares are no longer available. It's a case of counting teeth and measuring the diameter to calculate a MOD value, then use that plus gear thickness and shaft diameter to see if you can find a match for sale (ebay, AliExpress etc.) or order from firms such as kkpmo - KK Produkcja Mikroantriebe Producer of small pinion, spur gears, gearboxes, car system parts and other The latter option may not be cheap but it if gets a model working I consider it worth it. Link to comment Share on other sites More sharing options...
Deem Posted May 1 Share Posted May 1 I don't know if this will help but on ebay, these wheel are available with cog in the middle. On original wheel set hornby have traction tyres but these are without traction tyres, maybe you can remove the wheel on this shaft and put on your old wheel so you have a working cog in the middle. Maybe more experienced modellers can comment on this or give advice on this matter. Here is the link https://www.ebay.co.uk/itm/314571609125?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=pNeR1BfYSGC&sssrc=4429486&ssuid=nIMs5JBBS9W&var=&widget_ver=artemis&media=WHATS_APP Link to comment Share on other sites More sharing options...
Going Spare Posted May 1 Share Posted May 1 Again, this wheelset is for the HO Eurostar and there is no guarantee even the drive gear will be common with its 00-scale counterpart. Link to comment Share on other sites More sharing options...
LesXRN Posted May 2 Share Posted May 2 I bought a brass replacement axle cog for a Duchess from Ultrascale products. It might be worth checking if they can help. Link to comment Share on other sites More sharing options...
