Monty1970 Posted November 18, 2016 Share Posted November 18, 2016 Hi all,As a newbie i was wondering how many coats of acrylic paint i should give my models to get a even finish? Also should i coat with a Matt or Gloss cote after the painting stage?Many ThanksIan Link to comment Share on other sites More sharing options...
Ratch Posted November 18, 2016 Share Posted November 18, 2016 If you paint it properly you can get away with one coat. If that's not satisfactory, repeat as many times as necessary. You will need a coat of gloss as a foundation for any decals. The finishing varnish will depend on the subject. Link to comment Share on other sites More sharing options...
Monty1970 Posted November 19, 2016 Author Share Posted November 19, 2016 Cheers Ratch much appreciated Ian Link to comment Share on other sites More sharing options...
Dad Paul B Posted November 21, 2016 Share Posted November 21, 2016 It will depend on how dense the pigment is (Fluorescent Fire Orange needs four or five coats) and the type - satin finishes can be a pain for leaving watermarks as the pigment and carrier medium separate while drying.I would generally go for two coats and add more if needed. Link to comment Share on other sites More sharing options...
ironsides Posted November 22, 2016 Share Posted November 22, 2016 It will depend on how dense the pigment is (Fluorescent Fire Orange needs four or five coats) and the type - satin finishes can be a pain for leaving watermarks as the pigment and carrier medium separate while drying.I would generally go for two coats and add more if needed.Ditto usually two thin coats, with a broad flat brush of the best quality, followed by a thin coat of acryllic gloss varnish in areas where decals are to go, followed when dry by the decals applied with a decal solution... and finally a thin coat (or two) of Mattcote or any decent non yellowing matt varnish... .-) Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted November 22, 2016 Share Posted November 22, 2016 Slight variation here - I use Johnson's Klear floor wax rather than model varnish as a preparation for decals. Link to comment Share on other sites More sharing options...
Ratch Posted December 13, 2016 Share Posted December 13, 2016 I often hear folks cry that their paint won't adhere to the plastic, that the paint is expelled by the plastic. That's exactly what appears to be happening here. I decided to use Humbrol Acrylic 160 German Camouflage Red Brown for the floorboards of an old Airfix Brake Van and had this happenhttp://pic100.picturetrail.com/VOL761/13303934/24749108/413007336.jpgDisregard the white and maroon, they're OK for what I intend, and DON'T PANIC! With quick drying acrylic paints it takes just a few coats to cover.Second coat.http://pic100.picturetrail.com/VOL761/13303934/24749108/413007337.jpgNot quite right yet, but an improvement.Third coat.http://pic100.picturetrail.com/VOL761/13303934/24749108/413007338.jpgMuch better coverage, you can repeat as often as required. This took less than an hour, so you can see how quickly you can get a result. Link to comment Share on other sites More sharing options...
wcndave Posted January 4, 2017 Share Posted January 4, 2017 So, the suggestion here seems to be that you would do:Prime2 coats acrylic (normally)Gloss where decals go (gloss what?)Decals with decal solutionMattcote on topIn the old days I just did two coats of enamel and applied the decals, job done.Perhaps that's why most of my models weren't that great! Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted January 5, 2017 Share Posted January 5, 2017 @wcndave"Gloss" (varnish) overall before applying decals because they conform better over a glossy finish, "stick" better, and any transparent carrier film is less obvious. Link to comment Share on other sites More sharing options...
Yug Posted February 16, 2017 Share Posted February 16, 2017 Yeah, I've still got modelsI made when I was 13/14. A lot of them the decals have come off except the one's I coated with clear varnish. WELL I DIDN'T KNOW - THOUGHT THEY WERE SUPPOSED TO BE MATT. And there was no such thing as Decalfix in those days. Link to comment Share on other sites More sharing options...
dabhand Posted July 3, 2017 Share Posted July 3, 2017 Yeah, I've still got modelsI made when I was 13/14. A lot of them the decals have come off except the one's I coated with clear varnish. WELL I DIDN'T KNOW - THOUGHT THEY WERE SUPPOSED TO BE MATT. And there was no such thing as Decalfix in those days. My friends and me used to paint gloss varnish under the 'transfers' (as decals were called then) to make them stick. I remember using my first bottle of liquid cement to do the same job and remember how the transfers reacted - badly! Link to comment Share on other sites More sharing options...
