roythegrass Posted February 2, 2017 Share Posted February 2, 2017 I have a DCC Concepts rolling road and it works fine. In the packet was red wire with a crocodile clip at one end and a female socket at the other together with a metal strip and some screws. See photo.What is the purpose of these items? ThanksRoy /media/tinymce_upload/a166af8d877bd4bc2afb8e5388b7ccc8.jpg Link to comment Share on other sites More sharing options...
96RAF Posted February 2, 2017 Share Posted February 2, 2017 Go,to,post #25 herehttp://www.modelrailforum.com/forums/index.php?s=2890a7b2c5fc7823b41b0231bd13e655&showtopic=12217&st=15They appear to be 3-rail adaptrors for certain makes of track Including Hornby Dublo, Trix and Marklin. Link to comment Share on other sites More sharing options...
LCDR Posted February 2, 2017 Share Posted February 2, 2017 I can confirm that is exactly what they are. The instructions are not 100% clear , but if you are testing a three rail loco you screw the metal bit between the rails where you are going to test, (the loco pick up sits on top of it) then put the rollers on to the track round it. and the socket of the crocodile clip wire slots on to the tab at the end of the rail and clips to the supply lead, the other lead from the controller goes to the track. I have a set of these. Link to comment Share on other sites More sharing options...
