zeroOneman Posted February 23, 2017 Share Posted February 23, 2017 would it be possible to fit a keep-alive capacitor to your decoder? Link to comment Share on other sites More sharing options...
kangooman Posted February 23, 2017 Author Share Posted February 23, 2017 Funny you should say that zero. I was just reading about that.Or a stay alive decoder might be the simpler solution. Link to comment Share on other sites More sharing options...
kangooman Posted February 24, 2017 Author Share Posted February 24, 2017 Guys I think I may have it sorted.After me being all cocky about my baseboard I today put the spirit level and straight edge on it and found it was very slightly bowing upwards in the middle at the point where I had mad a support. I've removed the support and rechecked the flatness.Now this bow just happened to be where the points are. I have made the support a fraction too high and I think that's the problem.Train hardly stopping at all now, maybe just a little fiddling will get it perfect.Cheers Richard Link to comment Share on other sites More sharing options...
2e0dtoeric Posted February 24, 2017 Share Posted February 24, 2017 It takes courage to own up to a faux pas! 😛 Link to comment Share on other sites More sharing options...
kangooman Posted February 25, 2017 Author Share Posted February 25, 2017 Thanks 2e0dtoeric. I presume that means numpty in French 😳Now were cooking on gas.Ive sorted the dip out on the base board, and got the points all nice and flat. The little 0-6-0 now crawls over the point work.I think most of the problem was a newbie thinking he knows too much. Still hopefully other newbies will learn from my mistakesI expect I'll hit other problems, but at least I know where to come for freindly and helpful advice.Thanks again Richard Link to comment Share on other sites More sharing options...
Chrissaf Posted February 25, 2017 Share Posted February 25, 2017 I think most of the problem was a newbie thinking he knows too much. Still hopefully other newbies will learn from my mistakes..Hence my previous comment about taking advice from users with 100s combined years of experience. Main thing, it is now sorted. Link to comment Share on other sites More sharing options...
RDS Posted February 25, 2017 Share Posted February 25, 2017 Well done Fishy. You posted the correct solution in less than 2 hours. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 25, 2017 Share Posted February 25, 2017 Thanks RDS, 'twasn't difficult, there are any number of posts in the General forum, including very recent ones, saying exactly these 3 things (level (includes track pin in the middle of the point to achieve this), frog depth and back-to-back) and also reporting no problems with locos stopping when following them. I just plagiarised. Link to comment Share on other sites More sharing options...
Tomwilliams123 Posted September 17, 2018 Share Posted September 17, 2018 I have a similar problem with a class 142 pacer, it also stops on the points and so does my great western 0-6-0, if anyone could help that would be great, I heard you could stop the problem with tin foil Link to comment Share on other sites More sharing options...
Chrissaf Posted September 17, 2018 Share Posted September 17, 2018 The first thing to try before trying these old wives tales (rubbish ideas in my view) is to put an additional track pin in the point as close to the frog area as you can get. There is no pilot hole for it, so you will have to drill your own first. Extra pining down the centre area of Hornby points usually works..By the way, 0-6-0s are notorious for stalling on Hornby points. Link to comment Share on other sites More sharing options...
Howbi Posted September 17, 2018 Share Posted September 17, 2018 Clean track, clean wheels and ensure that the pick-up wipers are all touching the backs of the wheels and also are clean........use IPA (isopropyl alcohol).........HB Link to comment Share on other sites More sharing options...
walkingthedog Posted September 17, 2018 Share Posted September 17, 2018 Think I should get commission for the pin near the centre of the points idea. 😆 😉 Link to comment Share on other sites More sharing options...
Howbi Posted September 17, 2018 Share Posted September 17, 2018 Absolutely, Brian, a penny a point......... 😆..........HB Link to comment Share on other sites More sharing options...
walkingthedog Posted September 17, 2018 Share Posted September 17, 2018 Should be enough to buy you coffee and cake at Milton Keynes. 😉 Link to comment Share on other sites More sharing options...
Bulleidboy Posted September 20, 2018 Share Posted September 20, 2018 I think Peco points are pre-drilled from the underside - not obvious from the topside. Link to comment Share on other sites More sharing options...
GDG256 Posted September 25, 2018 Share Posted September 25, 2018 The first thing to try before trying these old wives tales (rubbish ideas in my view) is to put an additional track pin in the point as close to the frog area as you can get. There is no pilot hole for it, so you will have to drill your own first. Extra pining down the centre area of Hornby points usually works..By the way, 0-6-0s are notorious for stalling on Hornby points.Dear Chrissaf,I’m having a little trouble with Hornby points and with a few trains stalling on them. If it’s not too much trouble, are you able to take a photo of precisely where you recommend the additional track pin should go?Many thanks, Gareth Link to comment Share on other sites More sharing options...
Chrissaf Posted September 25, 2018 Share Posted September 25, 2018 Firstly I am just repeating a fix suggested previously by others on the forum. I have never had a need to resort to trying it out. Secondly, I do not use Hornby track. So a photo of my track would be ineffective. Sorry..Maybe somebody else who has actually used this fix will read this reply and post a photo..PS - If I had Hornby track and had used this fix myself, then I would have gladly posted the photo as requested. It would have been no trouble at all. Link to comment Share on other sites More sharing options...
Howbi Posted September 25, 2018 Share Posted September 25, 2018 I would suggest pin as illustrated.......a small hole would need to be drilled in the sleeper first.........HB/media/tinymce_upload/aae486ac019c5ae9afc1692592a41161.png Link to comment Share on other sites More sharing options...
GDG256 Posted September 26, 2018 Share Posted September 26, 2018 Thanks both for your replies. Link to comment Share on other sites More sharing options...
RDS Posted September 26, 2018 Share Posted September 26, 2018 ... Maybe somebody else who has actually used this fix will read this reply and post a photo... I posted a picture on page 2 of this thread, back in Feb 2017. ( I acknowledge that the idea was taken from member WTD). A 1.3mm hole is required. Link to comment Share on other sites More sharing options...
Howbi Posted September 26, 2018 Share Posted September 26, 2018 /media/tinymce_upload/b081d4d6cab8cb59d954ca7bdc24dfda.JPGYour excellent photo is worth showing again, RDS, combining both the point clips as well as the central track pin........HB Link to comment Share on other sites More sharing options...
