Twigman Posted November 5, 2017 Share Posted November 5, 2017 One of my cars (Scalextric McLaren Mp4-12C) has totally stopped working.I was racing when the C7042 APB went into SAFE mode.I removed the cars from the track, checked their braids weren't crossed, put them all back and everything was fine.For a couple of laps,Then APB jumps to SAFE mode again.I repeat the process.All cars apart from one restart functioning.I remove the body of the non-functioning car.I see no breaks in the wiring and no shorts where wires should not be touching.I replace the braids for new ones.I change the chip in the chassis for a new one.Nada - cannot get APB to see car. What's likely to have happened to it?What should I check next?What's gone wrong? The car is only 4weeks old and is my bairn's favourite.He's not happy Link to comment Share on other sites More sharing options...
Blagard-01 Posted November 5, 2017 Share Posted November 5, 2017 Well you are on the right track (excuse the pun). If other cars function OK then the problem must lie with the one car. It only takes one strand of the braid to cause a problem so also check the contacts between the guide and the cars fixed pickup contacts (the rigid silver bits on the end of the wires). Assuming you are running a digital car it is also possible you chave a chip problem.If a DPR car check the plug and make sure no strand of braid has got in there to short. Link to comment Share on other sites More sharing options...
gorp Posted November 5, 2017 Share Posted November 5, 2017 what do you mean by cannot get apb to see car ?does it run ?if so will it run on analog ?was new chip id ed ?does it work with different controller ?if you place lead wires on rails, will it run ? Link to comment Share on other sites More sharing options...
Twigman Posted November 5, 2017 Author Share Posted November 5, 2017 By cannot get apb to see car means that in prog mode, pressing the brake button does not ID carIt doesn't work with any controller.It doesn't work in analog. I discovered the problem:A capacitor leg has broken inside the ferrite man by the guide blade.Will build a new ferrite man. That'll fix it. Link to comment Share on other sites More sharing options...
gorp Posted November 6, 2017 Share Posted November 6, 2017 on the original digital porshe set cars, guide ferry man was weak pointfor more bad advice:have always removed guide ferry when it breaks and then resolder leads to guidebeen at least 10 years and they still work great without itbtw sf use to advise that Link to comment Share on other sites More sharing options...
Andy P. Posted November 6, 2017 Share Posted November 6, 2017 I think by ferry he means ferrite. Link to comment Share on other sites More sharing options...
Twigman Posted November 6, 2017 Author Share Posted November 6, 2017 Perhaps he's a Chris de Burgh fan? Link to comment Share on other sites More sharing options...
